UMI T-5/700R4 Trans Cross Member
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you have experience with the piece in question, please chime in.
http://www.umiperformance.com/catalo...roducts_id=139
JamesC
JamesC
Car: 84 Monte
Engine: 355 Chevy HSR
Axle/Gears: 3.90 Ford 9"
Re: UMI T-5/700R4 Trans Cross Member
Looks very similar to my spohn one, but I have the torque arm/crossmember with a loop, and that one is very sturdy.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i have UMI crossmember mounted arm, the crossmember is similar. Its a well made piece, fit great. and i did tap out the other 2 holes in the subframe
Car: 86 Trans Am
10mm-1.5 rings a bell, i have it in the garage, i can check
I've read that the metal is 'soft.' Did you torque to spec or simply snug up?
JamesC
JamesC
Car: 86 Trans Am
the metal is no softer than in the other holes. Maybe if there is a rust issue, you could have problems with the captured nut tearing out.
I didnt torque any of them to spec honestly. Just tightened "properly" by personal feel.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Rubber or poly mount? Vibration issues?
The install will occur early next week I hope. I'll review the piece, with pics at that point.
JamesC
JamesC
Car: 86 Trans Am
poly, i have a light vibe at high rpms, but its driveline angle related, been there since i put the tko600 in.
I currently have no issues with poly and my OE mount and its secondary cross member. If the UMI piece is to OE spec in height, I 'assume' all will be good to go.
JamesC
JamesC
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Nov 16, 2015 01:13 PM
