85 camaro + longshaft th400= will it work?
Old Jun 4, 2010 | 11:20 AM
tpi81's Avatar
Car: 85 Camaro-81 Chevy
Engine: 350-350tpi thats right tpi n my trk
Transmission: none-700R4 for gas
Ok I'm new to the forum and I have an 85 Camaro and was wondering will a longshaft th400 trans. work in it I've heard it should and heard i won't without some $$ into an cut driveshaft but I thought I'd ask some people that actually own a 3rd Gen.
Old Jun 4, 2010 | 05:14 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: 85 camaro + longshaft th400= will it work?
700r4 overall case length is 30.75 inch, th400 cases came in 28.375, 33.75, 37.875 inch. plus 700r4 output shaft is 27 spline and th400 is 32 spline.
Old Jun 4, 2010 | 05:54 PM
tpi81's Avatar
So i'd have to check the case length?
Old Jun 5, 2010 | 03:37 AM
Correct.
Old Jun 5, 2010 | 07:35 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Regardless of the case length, it CAN work. Will it drop in like factory and everything bolt up? No. You will need a crossmember for the TH400 and you will need a driveshaft of the correct length and with the larger trans yoke.
Old Jun 5, 2010 | 11:16 AM
tpi81's Avatar
thank you
Old Jun 7, 2010 | 02:20 AM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
You will need a cross-member also and you will need a torque arm mount of some sort too. I know from a th350 you will need a drive-line from an 1982 camaro if you can find one or get it cut. There also a good sticky at the top for more information.
Old Jun 7, 2010 | 03:09 AM
tpi81's Avatar
Ok I live in North Mississippi so being here in the south theres plenty of old junkers to go through and I'm getting the nose of an older camaro so maybe it's an 82 but another thing about the car is the previous owner had a built 327 in it so over years I'm not sure whats original and whats not I guess I'll just have to find out when I get to it LOL!! But thank you for the info!!
Old Jun 8, 2010 | 04:18 AM
Not if the TH350 is the 9" version, then you can use the 700's driveshaft
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
