700R4 Stuck in Drive
Old Jun 11, 2010 | 04:03 PM
ulmty's Avatar
Car: 1987 Iroc-Z Z28 Camaro
Engine: 5.7L TPI
Axle/Gears: Borg Warner 9-Bolt 3.27
Ok so I was pulling into my driveway, came to a stop and went to put it in park. The shifter moved without any of its usual resistance into park, but when i let off the brake it lurched forward. I tried every other position but it wouldn't click into any other gear.
I rolled it back and drove it onto some ramps to check the cable was connected. I had already checked up by the shifter itself. It seemed attached, but I don't have anything to compare it to. I pushed the shift lever and it clicked through the gears into Park. I was then able to start it up and shift into R-N-and D, but then it was stuck in D again.
It seems to me that once in park it ratchets out to shift properly, but the cable doesn't properly push the lever back up when going towards park.
Any ideas, diagrams, or suggestions are appreciated.
Old Jun 11, 2010 | 08:24 PM
Mitchell383's Avatar
Car: 1986 camaro IROC-Z Z28
Engine: 383 stroker stealth ram
Re: 700R4 Stuck in Drive
it happened to my car but it was stuck in reverse not sure if the same thing is going on but my shifter cable actually snapped inside the sleeve and i couldn't see it I must have drove it for awhile and it finally just frayed off but it was giving me issue like what your taking about before it went. hopefully thats all thats wrong.
Old Jun 12, 2010 | 09:44 AM
ulmty's Avatar
Engine: 5.7L TPI
It appears only to be a cable issue, because it drives fine in drive and shifts gears when I manually click the lever. I'll be replacing the cable and hopefully that will solve my issues.
Old Jun 12, 2010 | 05:02 PM
ulmty's Avatar
Engine: 5.7L TPI
I replaced the cable and all is well.
Old Jun 24, 2010 | 11:38 AM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
ulmty, what brand cable did you get? The only one I've been able to find is the Dorman cabel from the local parts stores. The cable seems lacking compared to the OEM one. The grommet doesn't seal, and the plastic that clips in the counsel is not fitting very well either. I am looking for GM, but it's been discontinued.
Old Jun 24, 2010 | 04:02 PM
ulmty's Avatar
Engine: 5.7L TPI
I could only find the dorman as well and seeings as I needed the car asap, I went with it. It works but doesnt snug in perfectly. I occasionally have trouble putting it in park, it will not travel perfectly and get stuck in between R and P. It has only happened twice in the last few weeks.
Old Jun 24, 2010 | 04:36 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
i had the same problem,i used a grinder to give the shifter a little extra travel (1/8 of an inch) forward into park.(under the shifter plate in the car.
Old Jun 24, 2010 | 08:48 PM
I got my cable right from My gm dealership in calgary. but thiers another store here that can still get OEM parts form another dealer in the states but i Cant remeber what the companys called that supplies them I can ask the dealership here if you want?
Old Jun 25, 2010 | 07:02 AM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Mitchell383, thanks. The GM part is discontinued, so you are lucky to have gotten one. 84 Z28 had recommended Hawks, they only had a few GM cables left. I got one through them.
BlueIroc-Z
Jun 9, 2019 03:22 AM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
jklein337
Sep 19, 2018 06:23 PM
Reddeath210
Oct 6, 2015 08:20 AM
