Carb/TH350 guys! Which kickdown cable are you using?
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I am trying to find a kickdown cable that will work. I have found some that are 36", 42", 46", and 39". Of course they have the universal that are cut to fit. Which one is working for you guys?
Im running a holley carb with the holley throttle/kickdown bracket.
I know lokar has and adjustable one, but im looking for a stock one that will work.
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: Carb/TH350 guys! Which kickdown cable are you using?
I have an earlier th350, but I use a pioneer ca1951. If you have a 350c trans, its a different number because the tube size at the trans is different
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I want to convert it to the top-hat type seal.
I checked a 81 camaro and it looked like the 700R4 cable with the button and the black rain drop connection at the carb. It looked cleaner, but it might be for the th350c.
All the other cables have the slide link on the carb.
As long as it works and seal off.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Im going to try the Pioneer CA-1951 you suggested. When I look it up on Advance Auto Parts, they list a 46" cable for the 75 C10.
Hopefully this will help others that do the swap.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
are you wanting to know more to seal up the hole in the tranny or to actually run? I disconnected my cable on my th350 in my s10. Id rather control my shifts. If I was to punch it with it hooked up in it, it would probably come close to putting me in the ditch everytime.
j/c
j/c
Car: Camaro
Engine: Carbed L98
Transmission: TH350
j/c
j/c
I am having a leak in the corner were the dipstick tube and the kickdown cable is located. I dont know which is leaking, but it needs fixed. I have a flexable double o-ring dipstick tube to replace the factory single o-ring. I couldnt find one with the sleave type seal that fit.
I do want to keep the option of running the kickdown cable, so I might as well replace it with the correct length version. I may never hook it up to the carb, but I can decide that later.
Oh yeah, with my 3500 converter and Hoosier Qtp's, I can appreciate the caution of the rear kicking out.
No I dont want to just plug the trans off.
Car: 86 IROC-Z, 82 z28
Engine: 383 Stroker
Transmission: TH-350
Axle/Gears: 3.73 Torsen, 4.56 Auburn
I just plugged mine off with a piece of fuel hose, permatex no2, and bolt with hose clamp. I kept having leaks from the area so I just got rid of it. I control my downshifts with the shifter if I have to which is very rarely since I run 3.73s. When I did run one tho, I used the one off a 1972 chevelle with 350 from advance auto parts.
Anyways, good luck!
Anyways, good luck!
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Anyways, good luck!
Anyways, good luck!
http://shop.advanceautoparts.com/web...S_603237042___
Did you have much slack in the cable? I assume that you just tuck it between the bell housing and firewall.
A guess as long as it fits the bracket and hooks up to the carb, the total length doesnt matter. Or am I wrong?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I just got a B&M kickdown for a TH350... the length is adjustable. Wasn't expensive either. Works well.
Car: 83 berlinetta
Engine: 305 roller motor
Transmission: th350
Axle/Gears: 10 bolt 3.08
I have an adjustable B&M cable that I got online at SUMMIT you can set to any length and they are not that spendy
. Thread Starter
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I assume you guys running the B&M cable are running this one.
http://www.summitracing.com/parts/BMM-30287/
Considering it is $34.99 plus S&H with would be another $11 its almost triple the cost of the Pioneer brand that Autozone carries for $15.99.
http://www.autozone.com/autozone/cat...&parentId=12-0
or at Advance auto for $19.99
I think I will try the Pioneer one from Autozone. I have used several pioneer products over the years and have had good luck.
9192camaro
16
Feb 3, 2019 12:21 AM
