Need a GOOD Clutch
Old 07-08-2010, 11:01 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Need a GOOD Clutch
Long story short the stocker doesn't like nitrous punishment
IDK who i should go with...Ram, Hays, Spec, Mcleod, Centerforce???? I'd like to keep it under $350 for a kit. It has to hold 150+hp of nitrous ontop of what the baby 305 has.
Thanks ALOT guys!!
Edit: 90% sure i'm goin with a McLeod http://www.summitracing.com/parts/MCL-75225/
Old 07-08-2010, 11:47 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Re: Need a GOOD Clutch
Just checked some part numbers...is the clutch different for a 350 vs a 305? I HIGHLy doubtit, but there ar 2 different part numbers
350 http://www.summitracing.com/parts/MC...RO&prefilter=1
305 http://www.summitracing.com/parts/MC...RO&prefilter=1
Old 07-09-2010, 07:24 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i use a center force dual friction still holds up to 5600 clutch dumps @ the track with slicks just make sure you break it in properly before you beat on it and it'll hold up
Old 07-09-2010, 07:54 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Many people have problems with the small weights sticking on the centerforce clutches, my Trans Am had that issue.
I've ran a RAM Power Grip and the Power Grip HD on my IROC. The HD was pretty grabby but always held up. The standard Power Grip works well too and has a more stock feel and easier engagement. I'm not sure the non-HD would hold my 383 on drag slicks, but I haven't tried it yet.
A friend of mine has had great luck with Hays clutches as well.
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
87 camaro iroc
08-20-2015 07:47 AM
redmaroz
08-16-2015 11:40 PM
rsrmoore
08-07-2015 08:44 PM
Quick Reply: Need a GOOD Clutch
