700r4 transmission shift kit installed but no reverse
Old Jul 16, 2010 | 11:23 PM
aaron83Z28's Avatar
i just installed a B&M shift kit in my 87 700r4 tranny and after getting it all together i dont have reverse it just slips but the thing is reverse worked fine b4 i put the shift kit in it, but it changes thru 1st 2nd 3rd and 4th fine. its full of ATF and the TV cable is fine. what would make it do that? plz no stupid answers
Old Jul 16, 2010 | 11:42 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: 700r4 transmission shift kit installed but no reverse
I got the same damb problem.
Old Jul 16, 2010 | 11:45 PM
aaron83Z28's Avatar
NO Shyt?
Old Jul 16, 2010 | 11:54 PM
Yup. I went to Kragens and when I was getting ready to leave, I shifted to reverse and nothing. I gave it gas to see if it would engage and nothing. i had to open the door and push back. Then it satrted to work agian but then it went back to the same junk. Then it worked, then it didnt. Now it just doesnt work. No reverse what so ever. 1,2,3,4 (OD) works just dandy.
Old Jul 16, 2010 | 11:57 PM
aaron83Z28's Avatar
idk wut it is tho. ima check the pressure value i was told that maybe it had something to do with it since i had to take it out and replace the spring maybe i didnt put it in right
Old Jul 17, 2010 | 12:01 AM
Pressure valve? where is that located at?
Old Jul 17, 2010 | 12:03 AM
aaron83Z28's Avatar
its on the front of the tranny (driver side) it has a snap ring holding the valve in place and its spring loaded
Old Jul 17, 2010 | 12:10 AM
Where is it at on this bad boy.
Old Jul 17, 2010 | 12:16 AM
aaron83Z28's Avatar
look beside the gear slector (left side from pic) there should be a hole to the top left area and in that hole is a valve it should have a blk snap ring. it goes into the pump but u dont have to pull the pump out. i cerciled the gerneral area it is in
Attached Thumbnails 700r4 transmission shift kit installed but no reverse-reman-tranny-2.jpg
Old Jul 17, 2010 | 12:18 AM
Good deal. Thanks bro.
Old Jul 17, 2010 | 12:19 AM
aaron83Z28's Avatar
you find it? u mite have to take off the filter
Old Jul 17, 2010 | 01:01 AM
Nah. Tranny is still in the Camaro. Probably in 2 weeks Ill get a chance. Ill keep you posted though. Thanks.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
