Auto to Manual swap
Old Jul 23, 2010 | 01:37 PM
marc12321's Avatar
Car: 1987 Camaro
Engine: 355 4bbl
Transmission: tko 600
Axle/Gears: 12bolt 3.73
Auto to Manual swap
Just completed my auto to manuel swap in my 1987 camaro. took only 2 days in my driveway. any questions on it your free to ask
Old Jul 23, 2010 | 02:29 PM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
Transmission: t5 non worldclass
Re: Auto to Manual swap
hey yeah i just did a auto to manuel swap and broke the plastic clutch hose so i am trying to figure out what else i can use i tryed a braided rubber line and the brake fluid ate through it in hours and it blow off any suggestions?
Old Jul 23, 2010 | 02:58 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
why'd it take so long? lol
we did 2 swaps in a day and a half on my driveway.
My auto into a friends 88 GTA and his T5 into my 88 Formula.
Had both cars on jack stands next to each other and just moved everything over.
Old Jul 23, 2010 | 03:19 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
try using braided steel line
Old Jul 23, 2010 | 03:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. Check the following link:
https://www.thirdgen.org/forums/engi...stainless.html
JamesC
Old Jul 23, 2010 | 11:29 PM
marc12321's Avatar
Car: 1987 Camaro
Engine: 355 4bbl
it took 2 days couse the delivery got messed up and i got my clutch late
Old Jul 24, 2010 | 11:11 AM
OddJack's Avatar
Hey Marc,
Were you able to get the clutch safety switch to work?
Clutch pedal has two switches, one back (safety) and one front, did you put any switches on the front and if you did where did you connect it to? (does your car have cruise control?)
What would you say was the toughest part? I hear those pedal screws are tough to get to, did you need to lower the steering so you could reach them from the top?
Old Jul 25, 2010 | 01:14 AM
marc12321's Avatar
Car: 1987 Camaro
Engine: 355 4bbl
ok ill anser your questions in order.
1. the auto shifter has 2 wires that are for safety so it only cranks in park. you can wire those to the safety in the pedel.
2. the hardest part was the 4 pedel screws and i did lower the steering colum (very easy to do). the clutch pedel has like 2 bars that support it put them in place after you tighten the 4 bolts or you will never get to them.
Old Jul 25, 2010 | 07:29 PM
OddJack's Avatar
One more question.. is the console for auto and manual the same? I opened the console today and seems like brackets that are attached to the console also hold down the auto shifter. ??
Old Jul 25, 2010 | 11:07 PM
Zepher's Avatar
check behind the drivers side kick-panel next to the fuse panel and see if you have the Clutch Safety Switch connector there.
My 88 had the connector for the Clutch Safety Switch tucked back there, so I just unplugged the switch from my friends 88 and plugged it into my 88.
Old Jul 26, 2010 | 12:03 AM
OddJack's Avatar
What did you do with the cable that goes from auto shifter to steering wheel? Did you remove it from steering wheel or just cut it?
Old Jul 26, 2010 | 12:45 AM
marc12321's Avatar
Car: 1987 Camaro
Engine: 355 4bbl
i just cut it and left it in there for now
Old Oct 11, 2010 | 08:58 PM
IROCUDREW's Avatar
Car: 1989 Chevorolet Iroc-z convertible
Engine: 383, holley terminator efi
Axle/Gears: stock 10 bolt w/ 3.73
im going to swap out my 700r4 for a 5 speed manuel. i found a v6 2.8 donor car i got the pedals from. What can i take from it and what do i have to buy? what did you use? And is the dust cover the same on the bell housing?
I also have a v8 in the car now. thanks in advance
Old Oct 24, 2010 | 01:04 AM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
i have a 5 speed from a 2.8 hooked on to my 350 it took me about a week to work out all the bugs. i had to get a adapter flywheel from jegs to connect my larger crank shaft bolt pattern to the pressure plate maybe it was just cause i had an older motor on there. oh and an adapter for the clutch plate because the v6 trannys use a 14 spline shaft and the v8s use the 26 spline shaft. witch cost i think 90.00 . and you will need to cut a whole in the fire wall for the master cylander luckaly there is a pattern in the rubber matt right under where the stearing colum bolts to the firewall. i disassembled the brake booster to do this. you have to unbolt the brake booster anyway to install the new clutch pedals.oh and now it works great i am most pleased with the out come oh and the v6s are geared lower so you feel like you change something for the better if you need any more info i will help if i can oh and get every thing you can EVERYTHING i was missing alot. good luck tell me how it goes
Old Oct 24, 2010 | 06:48 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi, you got a clutch disc to fit the 14 spline count on the v6 t5...and use a v8 pressure plate and flywheel....part numbers from jegs?
Old Oct 25, 2010 | 02:54 AM
bowtie88's Avatar
Car: 86 camaro z28
Engine: 67' 327
well sorry i guess my memory does not serve me well it was summit and i think i bought the 10.5in disc part#add-716104 cost:121.95 made by advance adapters they have an 11in as well part#add-716102 cost:157.95. i could not find one so i searched under s10 adapters. and i have headers and they burned my clutch hose so it took me a long time to locate adapters for our slave and master cyilanders to connect to a -3an fitting made by russell performance part number 640281 cost:21.99 and then i went on ebay and bought a -3an 18in clutch hose for ten bucks . oh and those adapters have a little lip on the bottom that i just barely ground off so they would fit right i ruined a few roll pins before i got it right and you have to install them with the master and slave out on a work bench so put them on before install. all pretty easy if you have do the right stuff in the right order
Old Nov 4, 2010 | 06:34 AM
capsfan101's Avatar
Car: 1992 camaro rs
Engine: v6
i am currently working on my swap and im about to put in the pedals and clutch hydro parts and i was wondering how you find the location on the firewall to drill the hole?
thanks
Old Nov 4, 2010 | 06:42 AM
JamesC's Avatar
Maybe something below:
https://www.thirdgen.org/forums/tran...y-t5-swap.html
JamesC
Old Nov 4, 2010 | 10:33 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I have some add'l information on that issue (fairly in depth IMO), covered in my T5 swap thread:
Old Nov 4, 2010 | 10:36 AM
capsfan101's Avatar
Car: 1992 camaro rs
Engine: v6
thanks that was exactly what i was looking for. now i just need the rain to stop so i can get out and get working
Old Sep 17, 2012 | 09:17 PM
RobTransAm's Avatar
Car: 1983 Trans Am
Engine: 350 naturally asporated
Axle/Gears: stock axels 373 richmond
Hi everyone, I'm new to this sight and still can't figure it out but I'm doing a swap on my 83 trans am and wanna know if I need to mess with the computer when or after I hook up the clutch wires. Since it was an auto before how do I let the computer know not to start er up un less the clutch is on the floor? and also how in the hell do I bleed the hydraulic ?!?!?! HELPHELPHELP (700r4 to a t5) (originally a 305 now a 350)
Old Oct 4, 2012 | 08:37 PM
SToneDaly's Avatar
do you have a complete list of all the tools you used? Even though you probably wouldn't recommend a beginner to take on a project like this?
Old Oct 4, 2012 | 08:43 PM
SToneDaly's Avatar
actually a better question would be do you guys think itd be better to buy an auto and swap it or just keep searching for a good manual? Ive come across pretty good auto Camaros but I cant find many manuals. If I got an auto for the prices ive seen I'd have maybe about $1k left over to put into the car
Old Oct 4, 2012 | 08:52 PM
Chris142976's Avatar
Car: 1991 trans am firebird
Engine: 355
Transmission: turbo 350
Axle/Gears: 5.13
i have a 1991 firebird that i have recently turned into a drag car..these cars came with the 700r4 transmissions and i was wondering if i can bolt a turbo350 transmission and it still fit..also will my stock torque arm work with this or do i need to buy a new weird crossmember..and wich crossmember is that
Old Oct 4, 2012 | 09:00 PM
Engine: 355
Axle/Gears: 5.13
i took out the stock engine and pute a chevy 355 in and want to use a turbo 350 will the turbo350 work on the crossmember?
Old Oct 4, 2012 | 09:25 PM
marc12321's Avatar
Car: 1987 Camaro
Engine: 355 4bbl
the torque arm is held in by a braket on the the trans tail shaft but the t350 dosnt have it. the tail shafts might be able to be changed but other wise you gotta change the cross member
Old Oct 5, 2012 | 12:01 AM
Aaron Muscato's Avatar
I know this questions probably answered but I'm 16 and I'm buying my brother's 86 Iroc-Z off of him. I just want to know what parts I need to convert from auto to manual. And which transmission and parts are best and the most affordable for a kid like me. Any replies would be appreciated
Old Dec 31, 2012 | 11:31 AM
whiskypig475's Avatar
I am doing a t5 swap in my 82 z28,I have a 1988 firebird formula donor car for all the parts,my 82 has a 700r4 tranny in it now,someone told me that I have to use a steering colume for a standard trans.is that true?I would love to keep my stock one in place.hope you can help.Ross
Old Feb 21, 2019 | 12:05 PM
Josh_furrburd91's Avatar
[QUOTE=marc12321;4618957]Just completed my auto to manuel swap in my 1987 camaro. took only 2 days in my driveway. any questions on it your free to
is it possible to swap the 700r4 trans in my 91 firebird 3.1 v6 to a manual? What trans will work? Would a older t56 work?
Old Feb 21, 2019 | 12:06 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You can use a t5
Old Jul 19, 2019 | 04:00 PM
davidsra's Avatar
Car: '91 RS
Engine: ZZ6
Axle/Gears: Stock 2.73
What speed sensor did you use for the T56? I (well my mechanic) swapped my 700R4 (1991 RS) for a T56 and the speedometer has been all over the place. I called Hawks and they said I need the $300 ELECTRONIC TO MECHANICAL SPEEDOMETER BOX, GM CLIP ON STYLE box. I don't understand that as my speedometer was electronic to begin with, the 700R4 didn't have a mechanical cable to the electronic speedometer.
What am I missing?
Old Jul 19, 2019 | 08:11 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
If your speedometer is electric, then you just need this
http://www.dakotadigital.com/index.c...rod/prd126.htm
Old Oct 15, 2025 | 08:36 PM
3rdgenCan's Avatar
What transmission did you go with and is the clutch pedal install easy ?
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
