will a 4L60 tranny fit into a 88 automatic iroc-z 5.0 tpi
Car: 89RS-5.0/88IROC-Z-5.0/92-5.7 z28/v6
Engine: 5.0/5.7/2.8
Transmission: 5 spd in two stock auto in other tw
Axle/Gears: stock
im thinking of buying this 93 donor car for the lt1 swap it has a auto transmission everything intact for 600-1000 (good deal???) so i will be needing a t56 but i was wondering for my dads 88 iroc-z 5.0 with tpi has a bad tranny (will not come out of second) so was wondering if i could switch the 4L60 from the 93 in place of the 700R4 because its shot. Has any body done this just wondering so i can revive my dads Iroc-z
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Re: will a 4L60 tranny fit into a 88 automatic iroc-z 5.0 tpi
you could if you got a stand alone tranny control unit.. the 4l60e which is what is in an
LT1 car is electronic controlled unit... basically the same tranny as te 700r4 just uses a computer instead of a throttle valve cable..
Engine: 5.0/5.7/2.8
Axle/Gears: stock
how much would it cost for the stand alone tranny control unit and what does it do?
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
http://www.summitracing.com/parts/TCI-377500/
Engine: 5.0/5.7/2.8
Axle/Gears: stock
i thought that the 93 z28 camaro had the 4L60 not the 4L60e
According to Wikipedia, you are correct. 93 was the last year of the 4l60. If this is the case, and the trans is not computer controlled, then it will go right it.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
4L60 is the same as the 700R4 - no computer needed to control it. 1993 Fbodies should have the 4L60, so its a direct swap. The 4L60E was the PCM controlled tranny (E for Electronic), and should not be present until 1994 models.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Is the tail shaft housing the same? If not it is easy enough to swap over. Im thinking of the torque arm mount.
Car: 1992 RS
Engine: Carbed 350
Yep - 4th gens had same rear, same torque arm, same length, etc. Only thing with the 4th gens that was different was the length of the rear axle (different offset on the rims).
Car: 92 rs
Transmission: 4L80E
yeah if its got the throttle valve cable on hooked to the side of the throttle body then it is the 4l60 but if it happens to be a late model 93 it might have the electronic...which wouldnt be worth the hassle...
Engine: 5.0/5.7/2.8
Axle/Gears: stock
hot dog sounds fun so if the throttle cable is connected to the throttle body then its 4l60
Car: 92 rs
Transmission: 4L80E
No not throttle cable... ( throttle vavle cable) also know as the TV cable it runs to the tranny when you accelerate the TV cable changes the line pressure on the tranny so you dont burn it up... do a search on TV cable in here it'll explain it all
Iroc8t8
May 4, 2026 08:09 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Sanjay
Aug 12, 2015 03:41 PM
