question on rear end..
Old Aug 11, 2010 | 10:25 AM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
hey, i have a problem. the PO of my camaro obviously did not know what they were doing cause my pass. side axle seal leaks. no biggie right? wrongggggg!! lol took the diff. cover off (3.73 posi gears) to unbolt the two bolts that hold in that thick pin to slide out my axle, when, uh-oh, one of the bolt heads is broke off, sticks maybe 1/4in out of the metal. cant grab it with vice grips. how should i get this out? also, im gettin a v6 camaro with a good rear end, has slip-lock rear tho. could i just swap the v6 rear with the v8? would it handle my motor? or easier just to get that one bolt out?
Old Aug 11, 2010 | 11:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: question on rear end..
Only one bolt holds the pinion shaft in place:
https://www.thirdgen.org/forums/tran...ing-axles.html
Rear ends are the same on V6's and V8's, though I'm unsure what a 'slip-lock' is. Limited slip, perhaps?
JamesC
Old Aug 11, 2010 | 12:32 PM
vinny83's Avatar
yeaaa, mine definently has two bolts one on each side. and the pin in thos e pics is small compared to mine. mines a good inch wide. as for the slip-lock, idk what its called lol. only one wheel spins on it, not a posi.
Old Aug 11, 2010 | 01:24 PM
JamesC's Avatar
yeaaa, mine definently has two bolts one on each side. and the pin in those pics is small compared to mine. mines a good inch wide.
Interesting. Unless, I've missed something, my parts and illustration cat. 82-91 shows only one bolt (82-91), Screw, Diff Png Shf p/n 140561696. And, Shaft, Diff Pin Gr. (Exc. G80), p/n 22507586.
EDIT (what follows is incorrect): Another source has the 82-85 locking Diff (BW) with what appears to be a bolt at both the top and bottom of the pinion shaft. Sound familiar?
JamesC
Old Aug 11, 2010 | 02:45 PM
vinny83's Avatar
yepp thats it..cept i got one off, spun it around to unbolt the other one, but its broken off..someone has grinded a lil groove in it to try and screw it out, but with no success i guess. wht u think i can do?
Old Aug 11, 2010 | 02:50 PM
JamesC's Avatar
While I'm not familiar with the diff in question, you might take a look at the tool I link to in post #2.
JamesC
Old Aug 11, 2010 | 02:56 PM
vinny83's Avatar
yeaa, im thinkin ill just get a set of reverse drilling bits and try to screw it out, if that doesnt work, ill weld a socket or nut to it, and try that.
Old Aug 11, 2010 | 05:32 PM
big gear head's Avatar
Please post some pictures of this differential. I've been building rear ends for every U.S. made car and truck for over 28 years and I've never seen one with a bolt in both ends of the cross shaft.
Is this a 10 bolt rear end or a 9 bolt?
Old Aug 11, 2010 | 07:29 PM
JamesC's Avatar
After looking at the diagram more closely, I see that only one bolt passes through the pinion cross shaft. There are two bolts, however, that appear to hold the unit together. I'll put pics up later.
JamesC
Old Aug 11, 2010 | 07:30 PM
vinny83's Avatar
will do sir..ill have to make an account on photobook or whatever, or tinypic to be able to post em. so give me a little bit lol =] but i will.
Old Aug 11, 2010 | 07:51 PM
JamesC's Avatar
Here's what I suspect you have: note the two bolts on one side, a single cross pinion bolt on the other.
JamesC
File Type: pdf
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
