detroit locker
Old Sep 15, 2010 | 03:04 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
detroit locker
I have a moser 9" with 31 spline axles, 3.70 gears, detroit locker and 12mm studs. Car is 3400lbs going down the track, has hoosier QTP's and TH350 with 4500 stall. I had a 406 that made 530hp and am currently buidling a 434 that should be making in the 675hp range + or - 25hp.
Will I have problems with the differential at the power level and the way my car is setup?
Thanks for any help.
Old Sep 17, 2010 | 02:20 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: detroit locker
that locker will hold that power only thing i would change would be the studs to 1/2 inch the 12mm are kinda wimpy
Old Sep 17, 2010 | 03:59 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Re: detroit locker
I've got the same setup with 35 spline axels and 1/2" studs and thing doesn't flinch. awesome setup!!
Old Sep 17, 2010 | 04:54 PM
big gear head's Avatar
Re: detroit locker
You are getting close to the point where you need to go to larger axles. The Locker is good.
Old Sep 17, 2010 | 05:15 PM
tom86iroc's Avatar
Car: 1986 iroc
Re: detroit locker
if those are moser axles and he twists them they told me they would upgrade mine for nothing i have 35 now and never had aproblem and don't think i'll be twisting these
Old Sep 17, 2010 | 08:01 PM
Re: detroit locker
Moser guarantees their 33 spline and up axles, but not 31 spline and down.
Old Sep 18, 2010 | 07:30 AM
tom86iroc's Avatar
Car: 1986 iroc
Re: detroit locker
been so long since i got mine thought it was for all of them thanks
Old Sep 18, 2010 | 03:38 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
Re: detroit locker
I called moser and they told me the 12mm studs were the least of my worries. Tech isn't worried about the locker either but is not sure how the 31 spline axles will hold up.
The thing I am worried about is the locker breaking and having the car make a hard turn into the wall. Maybe I am worrying too much?
Old Sep 19, 2010 | 07:17 AM
tom86iroc's Avatar
Car: 1986 iroc
Re: detroit locker
locker is a strong unit only thing stronger is a spool and cant run that after the motor is built take a couple runs and pull axle to see if its twisting at all then you'll know if you need to upgrade that's why i bought 35 first so i wouldn't have to upgrade at a later time
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
Nick McCardle
Sep 10, 2015 08:36 PM
DARKmj16
Sep 9, 2015 04:07 PM
