Leaky rear output seal with 9" housing ext
Old Sep 26, 2010 | 09:29 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I had my th350 built with a 9" housing extension so that I could use the stock driveshaft and rear end for a little while. I have maybe 200 miles on it and it leaks bad. There is a bit of slop in the output shaft too and I can see a gap between the seal and shaft. I launch and drive the car pretty hard. I'm worried that there may be too much stress on the end of the tailshaft due to its length. I'd like to run some nitrous out of the hole. If its not smart to run a long tailshaft with 700hp, I'm going to put it in my truck.
Old Sep 26, 2010 | 11:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Leaky rear output seal with 9" housing ext
Output shaft bushing is probably worn out. Length of the shaft isn't a problem.
Old Sep 27, 2010 | 03:59 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Ok. I'm using the tail housing off the old 700. The bushing is in the tail housing right? Thanks.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
