moser 9" hitting the body?
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
Ive got a moser 9" installed in my 84 t/a and there is a bolt on top that connects the panhard(?) bar to the trans, well when i go over a bump the bolt hits the body of the car, ive got eibach 1" lowering springs, would switching to a gta spring in the back help out this problem? i only have gta springs handy, no stock 84 springs, are gta springs lower than standard 84 t/a springs? stiffer? what other options do i have other than cutting a hole in my body where the bolt hits...and i dont really want to do that.
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: moser 9" hitting the body?
How are your shocks ? The rear end should be hitting the bump stops before anything else.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
thats normal with the moser 9 and lowered cars, it will "clearance" itself. I have a hole in the floor above and to the left of the tunnel from the bolt.
however, check to see if the rear is centered, it may be off to the driveside more and making it worse.
Engine: 2002 Ls1
Transmission: t-56
I have an adjustable torque arm? the bar that goes from left to right in the back, how do you adjust it? it might not be centered all the way, would it be easiest to do jacked up off the ground?
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
120ish from spohn or umi.
Yup, measure the distance from the wheels to the fender and then jack her up.
Engine: 2002 Ls1
Transmission: t-56
http://www.autopartswarehouse.com/de...e&apwidxPtRqZd
thats the one!
sweet, at least you can adjust that one on the car. worth the extra couple bucks!
Engine: 2002 Ls1
Transmission: t-56
Engine: 2002 Ls1
Transmission: t-56
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i just banged the body up with a hammer just enough to clear the bolts no biggie and you'll never know or see where you banged it up
Engine: 2002 Ls1
Transmission: t-56
Car: 1986 iroc
lol was for me just use a large drift to small you'll poke a hole and a big hammer 10 shots that's all it takes
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
