T5 or T56
Old Oct 14, 2010 | 06:34 PM
firehawk1724's Avatar
T5 or T56
Hey fellas I have a 89 trans am I bought a vortec engine from a 99 tahoe will a T5 or T56 blt up to it? And which trans is better? Can the T5 be built up or is the T56 better all around thanks in advance
Old Oct 14, 2010 | 06:47 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: T5 or T56
The Vortec engine is great, the t56 is good up to 450 horsepower stock, while the t5 is only rated at 300 HP stock. T56 also has an extra overdrive which will help out with your gas mileage. There are several threads if you do a search, of everything you need to swap to a t56 and the prices of those parts new.
Now I could be wrong, but from my understanding you do not need a new centerforce flywheel with the Vortec/86+ block because they are a 1-piece rear main seal. Could someone confirm this?
Old Oct 14, 2010 | 07:30 PM
Re: T5 or T56
Could I build the T5 up or it still wouldn't compare to the T56? Would there be any mods that were needed for one vs the other
Old Oct 14, 2010 | 08:58 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: T5 or T56
If you go with a t-56 your going to need new set of gears, 3.7x work well I find and you will also need a new crossmember.
With a t-5 you could upgrade it to the max with parts from G-Force, price would probably work out the same in the end though and not sure how much stronger it would be compared to the t-56 tranny.
Old Oct 14, 2010 | 09:34 PM
88gta6spdvert's Avatar
Car: 99 3000gt 88 gta vert 88 gta h/t
Engine: v6 /5.0 /5.7
Transmission: at/5 speed/at
Axle/Gears: ? /3.45/3.23
Re: T5 or T56
getting all stuff tohether for 6 spd swap on my tpi powered car what do the parts list look like that I need?
Old Oct 15, 2010 | 09:52 AM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: T5 or T56
https://www.thirdgen.org/forums/tran...after-t56.html
^(motivation?)
https://www.thirdgen.org/forums/faq-...questions.html
https://www.thirdgen.org/forums/tran...ap-thread.html
https://www.thirdgen.org/forums/tran...-overview.html
^(parts list) but you don't need the flywheel because you have the vortec block.
Old Oct 15, 2010 | 11:02 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: T5 or T56
What's involved coming from a t5 already to a LT1 style T56. I have searched, but haven't found an exact thread for my situation...
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
