Quick kickdown question
Old Nov 15, 2010 | 02:25 PM
tylerv350's Avatar
Car: 1982 z28/rs... haha
Engine: 305(now) 333(soon)
Transmission: 350 3-speed automatic
Axle/Gears: 3.45 limited slip 10 bolt
Alrighty, well i was just tinkering around with the kickdown cable on my camaro(th350) and the thought came to me... what happens if the cable gets engaged and youre only in first gear? im assuming there is some sort of thing that goes on that disallows the transmission to go out of first, but what? and also, what if you moved the point that the kickdown cable engaged to engage sooner, would that allow for quicker downshifts when you really put it at WOT? im just real curious about this, thanks a lot.
Old Nov 15, 2010 | 02:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Quick kickdown question
Nothing happens when you pull the cable out in first, there's no gear to kick down to.
Changing the cable configuration will change the point where it kicks down at part throttle, but won't do anything for WOT.
Old Nov 21, 2010 | 05:19 PM
tylerv350's Avatar
thank ya very much
Old Nov 21, 2010 | 09:45 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
i had a question about that too actually it seems my kick down cable provides quite some resistance against my gas peddle... as hell as does not allow my butterfly to open all the way now if i were to say bend the bracket towards to throttle body and relieve some of the tension on my kickdown cable aswell as allow my butterflies to open all the way?
Old Nov 21, 2010 | 09:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Are you talking about a TH350 cable or a 700R4 cable?
Old Nov 21, 2010 | 10:15 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
oh my bad 700r4
Old Nov 21, 2010 | 10:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The 700R4 TV cable is self-adjusting, the housing will extend further from the bracket if there isn`t enough travel at WOT.
Old Nov 22, 2010 | 05:23 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
yeah thats what ive heard but to me it doesnt make sense to why my butterflies only open barely 3/4
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
