700r4 not working
Old Nov 17, 2010 | 11:45 PM
91Camaro_RS's Avatar
700r4 not working
ok so i just swapped a L03 305 into my car, with a 700r4, motor runs great but when i put it in gear it doesnt move, the tranny has plenty of fluid. i talked to some guys and some said that the torque converter isnt seated all the way in, but others told me that there is no way i could have mated the motor and tranny if it wasnt seated all the way, also people asked me if i have my TC bolted to the Flexplate, yes they are bolted together, and yes the linkage for the shifter is installed right.
anyone have any idea why my car wont move?
i can give it gas with no brakes in any gear and it wont do anything
Old Nov 18, 2010 | 06:28 AM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Re: 700r4 not working
Do you know the history of this transmission? Was it bought with your L03 swap?
Old Nov 18, 2010 | 11:05 AM
car started out as a V6 car, bought a parts car and pulled out the motor and tranny, and now i just took that motor out and put in the L03, tranny has 129,xxx miles on it
Old Nov 18, 2010 | 03:01 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
A simple dumb question
Driveshaft is in right?
If everything checks out maybe it's time to do seenif the pump is working. A simple first check you can do is disconnect the lower cooler line from the trans and briefly start it and make sure it's pumping fluid out
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
