clutch problems
Old Nov 24, 2010 | 08:13 PM
hagerty438's Avatar
Car: 1985 Camaro Z28
Engine: 355
Axle/Gears: 7.5 with 4.11 gears
clutch problems
I just resently installed a t5 in my 1985 Camaro, and now every time that I drive it my clutch over heats, especially if I'm driving slowly through town. I think that the clutch fluid is boiling out of the resevior. Has anybody else had this problem, my clutch line is about 1.5 from my header.
Old Nov 29, 2010 | 12:47 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: clutch problems
Ive never seen that personally. I'm sure it can happen though. Either wrap the header or the clutch line with some heat reflective product and see what happens.
Old Nov 29, 2010 | 12:51 PM
Dyerseve1988's Avatar
Car: 91 Camaro RS
Engine: 355 4BOLT
Axle/Gears: Stock 10Bolt
Re: clutch problems
Happened to me 2 years ago. Did you put the factory shield back on over the slave cylinder? I had forgot mine cause the motor was out for a year. I put mine back on and wrapped the slave with stick on heat shielding. I also did the bellhousing because my custom y-pipe was a little to close for comfort, but you prob wont have that issue
theshackle
Aug 31, 2015 10:47 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
rsrmoore
Aug 7, 2015 08:44 PM
