Help with flywheel/flexplate on T5 swap
Old Nov 30, 2010 | 07:43 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Hi,
We have taken the 700r4 out of my 1988 IROC. I say 'we', but my man Richard from American Technique is doing it all .
The T5 that 'we' took off the donor car was mated to a 350 of unknown origin. It was an 86 IROC but the engine was a replacement so who knows?
Now- Rich is mating the T5 to my 305 tpi block but the flexplate is wrong and doesn't match.
We are really stuck on this and would really appreciate some input. Is there an adapter we should/could use? Do we need a new clutch?
Please help me Thirdgeners.
Cheers,.
Felix
Old Nov 30, 2010 | 08:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Help with flywheel/flexplate on T5 swap
You need a flywheel, not a flexplate.
JamesC
Old Nov 30, 2010 | 08:19 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks James- so what is the best way of getting me the correct flywheel and getting it quick in the UK? Thanks
Old Nov 30, 2010 | 08:25 AM
JamesC's Avatar
The 86 up version: one-piece rear main seal, 153 tooth, which will fit your 88. No clue about parts availability in the UK.
EDIT: Oh, and remember the pilot bearing.
JamesC
Old Nov 30, 2010 | 09:30 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Originally Posted by JamesC
There are two flywheels, IIRC: an 86 up, one-piece rear main seal, 153 tooth, and an 85 down, two-piece rear main seal, 168 tooth. If your 88 is stock, it should take the former. No clue about parts availability in the UK.
Jamesc
Good man! Thanks James and the pilot bearing is here already
Old Nov 30, 2010 | 02:30 PM
American Tech's Avatar
Car: Camaro
The old flex plate which we took off and the new flywheel we are fitting are both 153 tooth but the holes for the crank are alot further apart on the flywheel could it of been a older 350ci say a 2nd gen?
Old Nov 30, 2010 | 03:32 PM
JamesC's Avatar
IIRC, the one- and two-piece rear main seal versions have different bolt patterns. Could that be the issue? Check post #13 of the following link for pics:
https://www.thirdgen.org/forums/tran...hwheel-my.html
JamesC
Old Nov 30, 2010 | 03:47 PM
Car: Camaro
The crank is the same as the top pic being its a 88 but the flywheel we took out the donor does not look like either of the ones in the pic.
But the crank did look like the bottom pic on the donor engine we sold.
So the ideal solution is just get a flywheel for a 88?
Old Nov 30, 2010 | 04:04 PM
JamesC's Avatar
Yes.
JamesC
Old Dec 1, 2010 | 03:33 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks James- appreciated!
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
