can someone clear 3rd gen to 4th rear 4 me
Old Dec 2, 2010 | 01:04 PM
89fbrestor's Avatar
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
i posted a thread a while ago asking about putting a 4th gen rear end into my 3rd gen and those who replied said they were totally different and couldnt be swapped. now i'm reading threads and people talking about putting them in there 3rd gens. i'll be the first to admit i'm no gear head but whats the truth.
Old Dec 2, 2010 | 01:18 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: can someone clear 3rd gen to 4th rear 4 me
The control arms and shocks bolt right in.
Other details:
https://www.thirdgen.org/forums/tran...-gen-rear.html
Old Dec 2, 2010 | 01:27 PM
89fbrestor's Avatar
ok so they can bolt up with out cutting and welding etc. thank you
Old Dec 2, 2010 | 01:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Baloney.
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Dec 2, 2010 | 01:55 PM
89fbrestor's Avatar
baloney that they said that to me or I'm lying that i was told that?
Old Dec 2, 2010 | 02:29 PM
JamesC's Avatar
Baloney to those that told you the swapped couldn't be effected.
JamesC
Old Dec 2, 2010 | 02:39 PM
Stephen's Avatar
Car: 87 GTA
Whoever told you that, couldn't have been from here on TGO. That, and sorry to say this, but they are idiots. It has only been done thousands of times with very little changes or modification needed.
Old Dec 2, 2010 | 03:20 PM
89fbrestor's Avatar
thanks jamesc, its always nice being called a liar. anyway i asked back in 2007 if i could put a 2nd gen rear in my firebird and was told that the only rear that would boult in with out modifications was the 3rd gen. "sofakindom" told me that and that the 93 to 02 rears were close but would still need some work. anyway like i said i'm not gear head and now i know they will (thank you for link jamesc even though you called me a liar) so i will pursue that rout.
Old Dec 2, 2010 | 03:40 PM
JamesC's Avatar
Hey, 89,
I don't think you're reading me right. I edited post #6 to more clearly state my opinion. Forgive the miscommunication.
JamesC
Old Dec 2, 2010 | 03:49 PM
89fbrestor's Avatar
no biggy jamesc i took it lightly and responded lightly. i love everyone on this site it has been such a major help for someone like me who is not a gear head but still has a passion for playing with cars. this is my 7th 3rd gen and as i get older(mid 30's) my love for these cars is still just as strong now as it was when i got my first one. thanks again for that link i plan on looking for a posi rear to swap out now take care.
brian
Old Dec 2, 2010 | 03:57 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I've read that the 4th gen rear end is wider so is it a good idea to use wheels with less backset than 3rd gen wheels?
Old Dec 2, 2010 | 04:28 PM
Stephen's Avatar
Car: 87 GTA
You can use stock 4th gen or Vette wheels & it'll line up good. Or use stock 16" 3rd gen rear wheels, or aftermarket wheels that have the same backspacing/offset as stock 16" 3rd gen rear wheels.
Here is a 3rd gen (the blue RS) with a 4th gen rear axle & stock 3rd gen 16" rear wheels.
Old Dec 3, 2010 | 05:47 AM
89fbrestor's Avatar
nice, i like the way it looks
Old Dec 5, 2010 | 06:02 PM
camarito's Avatar
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
you can use the stock 15" rims too i just put a 02 rear on my 84 and the 12" brakes do clear the 15's, barely but they do, the only thing that didn't work was the parking break cables everything else fits perfect
Old Dec 5, 2010 | 06:23 PM
JamesC's Avatar
Originally Posted by camarito
...the only thing that didn't work was the parking break cables everything else fits perfect
The LS1 cables are available from Ed Miller.
JamesC
Old Dec 5, 2010 | 06:38 PM
camarito's Avatar
JamesC
mine came with the ls1 cables and the sleeve is too long so the cable doesn't reach the adjuster if you use the stock mounting points (on a 3rd gen with drum brakes), either you make a custom bracket or get factory cables for a 3rd gen with disk brakes, you might still have to modify them a little to fit but it's not a hard task
Old Dec 5, 2010 | 08:31 PM
JamesC's Avatar
Perhaps I should have said LS1 "custom" cables:
http://www.flynbye.com/catalog/i153.html
JamesC
Old Dec 5, 2010 | 09:01 PM
iroc-z_23's Avatar
Car: 1986 Iroc-z Camaro t-top
Engine: 355 SBC
Transmission: 700r4 TCI const. Pres. Valve body
Axle/Gears: 3.73 posi/mosuer axles
I've heard of people putting in 3rd gen rear ends in 4th gens? Are they stronger than 4th gen?
Old Dec 6, 2010 | 05:50 AM
camarito's Avatar
JamesC
Ouch, a little overpriced I think, you can get the 3rd gen to fit with minor grinding for less than $30 bucks
Old Dec 6, 2010 | 06:24 AM
JamesC's Avatar
No stronger than thirdgen axles with 28 splines.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
jbd1969
Aug 17, 2015 07:06 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
