is there a factory dana 44 application that uses the same cover gasket as the rare thirdgen dana 44?
I need a gasket for mine. The 96 vette irs gasket is different and a 75 jeep is different judging from picts. I need an application so that the parts moron can look it up at the store.
I haven't used a diff cover gasket on a car since the early 80's. A bead of RTV silicone works just as good.
I would think that almost any rear wheel drive solid axle Dana 44 would use the same gasket.
Yeah I would have thought the same so I looked up the jeep dana 44 gasket and it looks different.
I might just end up doing the rtv thing.
I thought summit used to sell both and had nice pictures... Im pretty sure the f-body dana 44 is like the jeep
Quote:
according to summits fancy pictures, the dana 44, 50 , 60 and 70U share the same cover pattern. The vette/viper dana 44 IRS is different entirely.Originally Posted by 88 350 tpi formula
I thought summit used to sell both and had nice pictures... Im pretty sure the f-body dana 44 is like the jeep i've been using RTV in place of the gaskets for years. Never had any luck getting teh gaskets to seal.
Quote:
They seal fine when you put enough RTV on them. Originally Posted by //<86TA>\\
Quote:
im sure they doOriginally Posted by Apeiron
