auto to manual
Old Dec 16, 2010 | 02:18 PM
IROCZdude's Avatar
Car: 88' Z
Engine: 350 .60 over
Transmission: W/C T5
auto to manual
im going to make it simple.
how hard is it and how much would it cost to go from a 700r4 to a t5
Old Dec 16, 2010 | 02:42 PM
rallyup91's Avatar
Car: 1991 Camaro RS
Engine: 350 H.O. (330hp/400ft.-lbs)
Axle/Gears: 3.73 limited slip
Re: auto to manual
I know that www.hawksthirdgenparts.com has a T5 transmission kit that cost $1200. Thats a pretty good price concidering it comes with everything you need to make the swap. I've been planning to do this myself and from what I have read, it dosen't seem to difficult. It just takes good bit of man hours, and having all the right parts.
Old Dec 23, 2010 | 11:42 PM
IROCZdude's Avatar
Car: 88' Z
Re: auto to manual
it dosent even give you a list of everything it comes with? it just says everything you need
Old Dec 24, 2010 | 01:44 AM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
Re: auto to manual
I just did an T56 swap only real work was making the trans cross-member and cutting the hole in the floor, every thing just bolted in.
Old Dec 25, 2010 | 02:31 AM
bduffey723's Avatar
Car: not a camaro anymore
Re: auto to manual
lol i thought the same thing. i figured they know what they re doing it shuld all be there. if u get it and call them and be like hey "this" isnt there im sure they'd help u out.
Old Dec 28, 2010 | 09:27 PM
IROCZdude's Avatar
Car: 88' Z
Re: auto to manual
well i read the tech article on doing a t5 swap...sounds like the hardest part would be hanging the pedals. but im still confused, if im reading it right it says you need to get a new brake booster and master cylinder ?
Old Dec 29, 2010 | 04:20 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: auto to manual
no you dont need a new brake booster or MC...you have to take them off the car though to remove the automatic brake pedal and install the manual brake pedal and clutch. it was the biggest pain in the hole project becuase the nuts are hard to get to.
before you put the new pedals on you need to make a whole for the clutch hydraulics...on mine all i had to do was look under the dash you can see exactly where it is supposed to go, its already cut out of the insulation on the firewall. thats where the hole goes.
hang pedals, hook them up and put everything back together
Old Dec 30, 2010 | 10:07 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
Re: auto to manual
the booster and master cylinder are the same,,but a must is to change the proportion valve...if you had disc-drums...the prop valve is not the same...you need a disc - disc prop valve to give the rear the right brake pressure,,,the rest is pretty simple.
Old Jan 2, 2011 | 10:13 PM
IROCZdude's Avatar
Car: 88' Z
Re: auto to manual
could you post some pics of your pedals and you said the insulation was cut out and thats where the pedals go ?
Old Jan 2, 2011 | 10:16 PM
Pillsbry10's Avatar
Re: auto to manual
thats where the master cylinder will go through the fire wall...the pedals bolt to the studs on the brake booster(studs go through firewall to inside under dash)
id take you some pics but car is currently not at my house
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
RyanJB
May 7, 2016 06:23 PM
88rscamar0
Sep 23, 2015 09:08 PM
Magman
Sep 12, 2015 11:55 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
