700r4 Performance Torque Converter?
Old Dec 24, 2010 | 03:28 PM
xxiamdrewxx's Avatar
Car: 86 Berlinetta/84 s15
Swapping this transmission from my Camaro into my truck. I am going to be putting in a shift kit. With the kit I would like to install a new torque converter. So I am looking for a cheap performance one for around 150 bucks or so. I don't have much experience with this sort of thing so I figured I would ask. The truck is mostly driven around town between 30-50 mph if that helps. Also I would like to change the gears in the rear if anyone has any suggestion on that route. Thank you very much in advance and happy holidays!
Old Dec 26, 2010 | 01:51 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Re: 700r4 Performance Torque Converter?
you need to know if you have a 27 or 30 spline trans input shaft. if you have a 27 spline, pm me, i have a new 2600 stall unit from a very good maker.
Old Dec 26, 2010 | 10:21 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
In my area, a stock reman converter starts at $200.
Your budget will likely get you a good used unit.
I had one on my shelf for 6 months, and could not give it away. Finally hit the trash about 2 weeks ago.
Old Dec 26, 2010 | 04:52 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Look into a converter from a 4.3l V6 S-10 pickup. Behind a 350, they stall at around 2000 - 2200, stock stall is only like 1300. Not a radical street or track converter, but makes a better street feel over stock. I bought mine about 4 years ago from GMPartsDirect.com and was about $150 shipped. If you search s-10 converter you'll see older threads on here about the specifics.
Old Jan 2, 2011 | 10:23 PM
irocket87's Avatar
Car: 87 Iroc Camaro
Engine: 5.0
so if say i pulled a stock convertor out of a 4.3 S10 itd be about a 2000-2200 stall in our cars?
Old Jan 3, 2011 | 02:36 PM
Car: 1992 RS
Engine: Carbed 350
It will stall around the 2100 mark behind a basic 350 give or take. Stall depends on a variety of factors, and you can't simply say a converter will stall at a given rpm - there will always be some fluctuation, but pretty close. Search S-10 Converter here and you'll see the old threads about it. Old because not too many folks do it anymore - I guess they like spending more on new aftermarket brands - but in my book if it works the same and costs less, I'm there!
Old Jan 3, 2011 | 03:27 PM
irocket87's Avatar
Car: 87 Iroc Camaro
Engine: 5.0
hmmm thats around the stall i wanna put in my car, hell if its cheaper why not. you say behind a basic 350 so would it be prolly the same for a 305?
Old Jan 3, 2011 | 07:02 PM
Car: 1992 RS
Engine: Carbed 350
Not 100% sure exactly how all that works, so I don't know. Probably be close - might wait to see if someone else chimes in, or do an internet search for how they stall and under what conditions
Old Jan 3, 2011 | 11:36 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
summit converters are made by TCI. They have a 12 inch converter with like a 2200 stall for 200 bucks. not a bad deal at all. I am running thier 2600 stall and I have had no problems with it.
Old Jan 4, 2011 | 05:51 PM
irocket87's Avatar
Car: 87 Iroc Camaro
Engine: 5.0
That sounds like a pretty good deal as well...right now im just trying to get the best bang for the buck
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
deracer
Apr 11, 2016 12:04 AM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
