10 bolt pbr calipers on a 9 bolt?
Old Dec 31, 2010 | 08:55 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
I have a 1989 or 1990 10 bolt in my 1986 camaro right now, but i need to replace it. i found a 1984 9 bolt for a decent price but it doesn't come with brakes. can i swap the aluminum PBR calipers on to the 9 bolt?
thank's in advance for your replies!
Eric B
Old Dec 31, 2010 | 09:04 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 10 bolt pbr calipers on a 9 bolt?
Only if you can find 9 bolt PBR disc backing plates which were only available in 1989.
Old Dec 31, 2010 | 09:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Available here:
http://www.flynbye.com/catalog/i31.html
And here:
http://www.andyz28.com/3rdGen/reardisc.html
JamesC
Old Dec 31, 2010 | 10:14 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
thanks guys!
this is why i love this site, you mods are always on it!
E
Old Dec 31, 2010 | 11:13 AM
No such thing as a 84 9-bolt.
The 9-bolt first appeared in certain 85 Firebirds.
Which is NOT the same as saying, a 9-bolt that happens to be in a 84 car ATM; since anybody can jam any 3rd gen rear under any 3rd gen car, regardless of year.
OTOH, if you haven't seen it, and all you're doing is quoting a CL ad or some such as it sounds like, don't get your hopes up too high; you might get there and find yourself looking at an actual 84 rear, which would be a 10-bolt, with one of the cover bolts missing. Don't weep, it's happened before. Will probably happen again.
Moral of the story is, look before you leap.
Old Jan 1, 2011 | 09:19 AM
JamesC's Avatar
Eric, if you or anyone else has the opportunity (or could provide the info), would you measure the rear from the outside of one end of housing to the other? I'd like to know the width of a thirdgen rear.
Many thanks,
JamesC
Old Jan 2, 2011 | 12:27 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
good point about the production years sofa, i had wondered about that. I have seen pics of it and it is a 9 bolt, but i don't have any numbers off it.
James, i will measure and let you know, but it will probably be a week or so.
Old Jan 2, 2011 | 07:02 AM
JamesC's Avatar
Originally Posted by SLEEPER 86
I have seen pics of it and it is a 9 bolt...
I figured the 9-bolt description was correct (hard to mess that up), but that the seller didn't know the year and was guessing. At any rate, Sofa's correct about being careful.
Thanks. I appreciate your effort.
JamesC
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Jlanz55
Sep 6, 2015 07:28 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
