BW 9 BOLT 7.75" 2.77 RATIO NOT SURE HOW TO REPLACE AXLE BEARINGS + SEALS . NEED HELP.
Old Jan 4, 2011 | 10:10 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
ANYONE DONE AXLE BEARING / SEAL AND/OR PINION SEAL REPLACE ON BW 9 BOLT REAR END ???? THE BOOK IS NOT CLEAR ON WHAT SPECIAL TOOLS ARE REQUIRED AND HOW TO GET BEARINGS AND SEALS OFF THE AXLES . HELP.
Old Jan 4, 2011 | 10:49 AM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Re: BW 9 BOLT 7.75" 2.77 RATIO NOT SURE HOW TO REPLACE AXLE BEARINGS + SEALS . NEED H
Tips/Tricks for Installing Axles, Bearings, Seals
It was under the sticky at the top of this forum. Has pictures and everything.
Old Jan 4, 2011 | 10:54 AM
DRIVE2FAST's Avatar
THE HOW - TO IS FOR THE C-CLIP TYPE AXLES WITH BEARINGS IN THE HOUSING. BW 9 BOLT HAS BEARINGS PRESSED ON AXLES WITH INNER RETAINERS THAT MUST BE DESTROYED IN ORDER TO REPLACE BEARINGS AND SEALS. THE BOOK I HAVE IS NOT TOO CLEAR ON WTF TO DO.
Old Jan 4, 2011 | 11:00 AM
big gear head's Avatar
That only covers the 10 bolt. The 9 bolt has completely different axle bearings. The 9 bolt has the bearings pressed on the axles. The axles will have to be removed and taken to a shop where the bearings can be pressed off and new bearings pressed on. The right and left bearings and seals are not the same, so you will need to get the correct bearings. The axles are held in by the bolts that hold the caliper brackes on.
Old Jan 4, 2011 | 11:03 AM
DRIVE2FAST's Avatar
I GOT THE AXLES OUT. ONE SIDE LOOKS LIKE ITS BEEN LEAKING. THE BEARINGS SPIN/LOOK OK. THE BOOK I HAVE SUKS. I FIGURED GOOD IDEA TO REPLACE SEALS BEFORE I PUT THE REAR END BACK ON THE CAR. ANYBODY DONE FRONT SEAL ON BW 9 BOLT ? IS IT MORE COST EFFECTIVE TO TAKE AXLES TO SHOP FOR SEALS ?
Old Jan 4, 2011 | 11:15 AM
I have rebuilt the 9 bolt rear ends before. Changing the pinion seal is no different from changing the pinion seal on other GM rear ends.
Old Jan 4, 2011 | 11:19 AM
DRIVE2FAST's Avatar
DO I NEED ALOT OF SPECIAL TOOLS FOR FRONT SEAL CHANGE ?
Old Jan 4, 2011 | 11:29 AM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Replacing the pinion seal is the same as almost every other rear end, gm or otherwise.
I usually count the threads, and put a mark on diff yoke nut, so it can be reinstalled to about the same torque.
Pull the big nut off the center of the axle yoke, remove the yoke and use a seal puller or large screwdriver to remove the seal. Tap new seal in till its flush, and reinstall yoke.
The axleshaft bearings and seals can be done if you have a press. If not, take it to a machine shop and have them do it.
Old Jan 4, 2011 | 11:47 AM
supr_fly03's Avatar
Car: 83 Z28
I didnt know that 9 bolt axles are semi-float. I have a press, but it is not big enough for that, buy the correct bearings/seals for your axle shafts and pay a machine shop to press them on and off.
The pinion seal is easy. All you need is a 1/2" drive torque wrench to retorque the pinion nut. Oh and the socket for the pinion nut.
Old Jan 4, 2011 | 12:30 PM
DRIVE2FAST's Avatar
IVE GOT A PRETTY BIG ARBOR PRESS I GOT FROM AN OLD AIRCRAFT WHEEL TIRE/ SHOP THAT MY JET ENGINE SHOP WAS NEXT TOO. I DONT HAVE THE DRIVERS AND/OR PULLERS I ASSUME I NEED TO GET THE AXLE BEARINGS ON/OFF. THE PRESS WORKS LIKE A CHAMP FOR WHEEL STUD REMOVAL AND INSTALLS.
Old Jan 4, 2011 | 12:33 PM
DRIVE2FAST's Avatar
IS THERE A TRICK TO KEEPING EVERYTHING FROM TURNING WHEN REMOVING / TIGHTENING PINION NUT WHEN THE AXLES ARE OUT ?? THE BOOK SHOWS ANOTHER SPECIAL TOOL...
DRIVE2FAST's Avatar
THE BOOK SAYS TO BREAK THE INNER RETAINER WITH A CHISEL. WTF ??!!
Old Jan 4, 2011 | 01:44 PM
supr_fly03's Avatar
Car: 83 Z28
Yes to all of that. In a pinch I have used a large pipe wrench on the yoke, but it tears them up. I made a tool to hold the yoke through the bolt holes with a long extention.
There is a ring that holds the bearing on the axle, the only way to get it off is to partially cut through it and then break it open with a chisel. Be careful when cutting the ring so you dont nick the axle shaft.
Old Jan 4, 2011 | 02:33 PM
DRIVE2FAST's Avatar
WHERE DO I GET A NEW BEARING RING ? IM NOT SEEING ANY INCLUDED WITH THE SEAL KITS.
Old Jan 4, 2011 | 02:36 PM
DRIVE2FAST's Avatar
IT LOOKS LIKE THE INNER RING COMES WITH A NEW BEARING. DAMN. DONT NEED NEW BEARINGS.
Old Jan 4, 2011 | 05:20 PM
You can't change the seal without changing the bearing too. You will destroy the bearing when you try to get it off. There's no way around it.
Old Nov 23, 2011 | 07:08 PM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
how do you get the axles out of the rear end ?
Old Nov 23, 2011 | 07:32 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Please take your caps lock button off. No need to yell at us. thank you
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
Leggman1
Aug 6, 2015 04:15 AM
