B&M Cable with stock shifter?
Old Jan 8, 2011 | 09:02 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I've searched this and only found the opposite where people use the stock cable with the B&M shifter.
I have a B&M shifter in my car right now, and that's what it had when I bought it. I want to put a stock shifter back in, and I want to know if I can sue the B&M shift cable with the stock shifter. Maybe a picture comparing the ends of the stock cable vs. the ends of the B&M cable? I imagine they're the same.
Old Jan 8, 2011 | 11:05 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: B&M Cable with stock shifter?
the b&m shifter has a built in bracket to hold the cable so you would need to mod that. then you have to measure the distance from the pivot to the cable tab. if it isn't the same it will be bad news. i recommend swapping the cable and all the brackets.
Old Jan 9, 2011 | 08:32 AM
chevydrvr's Avatar
Okay I'll probably just look in the junkyard or something for a stock cable. Unless I can figure out how to make this work. Thanks!
Old Jan 14, 2011 | 05:56 PM
chevydrvr's Avatar
Could anybody possibly post pics showing the end of the stock cable against the end of the B&M cable?
Old Jan 16, 2011 | 05:52 PM
chevydrvr's Avatar
Does anybody know if a 4th gen stock shift cable will work in a 3rd gen with a stock shifter and a 700r4?
BewleyBizzIROC
Feb 3, 2020 09:52 AM
NBrehm
Aug 25, 2015 11:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
