rear end problem help please!!!
Old Jan 14, 2011 | 03:01 PM
sloatgnc's Avatar
Car: 1989 chevy camaro
Engine: 305 tbi
Axle/Gears: 2.73 gears
i have a 1989 camaro and i was wondering what would cause the rear wheels to slide in and out a little bit when on jack stads would it be a worn bearing or something
Old Jan 14, 2011 | 03:19 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: rear end problem help please!!!
A tiny bit of play straight in and out is normal. The axle shafts hit the pin in the middle when you push them in, and the C-clip when you pull out. There shouldn't be much play though, like 1 or 2mm at most..
Old Jan 14, 2011 | 03:42 PM
sloatgnc's Avatar
Engine: 305 tbi
well it feels like it moves more than that mabye a 1/4 of an inch if not a little more
Old Jan 14, 2011 | 08:07 PM
big gear head's Avatar
You probably have an Auburn differential that is just about worn out. When it stops spinning both tires change it out and get an Eaton Posi and your problem will go away.
Old Jan 14, 2011 | 09:45 PM
sloatgnc's Avatar
Engine: 305 tbi
is there a cheaper fix until i can afford that
Old Jan 14, 2011 | 10:41 PM
Don't worry about it. Just drive it and save your money. The axles are not going to come out, as long as you don't break the Auburn. If the auburn is worn out then it's going to be weaker, so don't beat on it too much.
This is all assuming that you have the Auburn.
Old Jan 15, 2011 | 12:50 AM
sloatgnc's Avatar
Engine: 305 tbi
how can i tell for sure that it is an auburn for sure
Old Jan 15, 2011 | 06:33 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Jerk the diff cove and take a look. Pics in the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jan 15, 2011 | 11:39 AM
Does it, or did it sping both tires when doing a burnout? If it did then it probably had the Auburn. There were only 2 limited slip differentials offered in the 3rd gen and they were the Auburn and the Governor Lock. The Gov Lock usually doesn't have excessive axle end play from wear, but the Auburn will.
Old Jan 15, 2011 | 11:45 AM
sloatgnc's Avatar
Engine: 305 tbi
it spun both tires one time since i've had it but now it only spins one
Old Jan 15, 2011 | 11:48 AM
You probably need to remove the cover and see what is in there. You are probably going to find a bunch of metal sludge in the bottom of the housing. You need to find out why the axles are moving as much as they are.
Old Jan 15, 2011 | 12:03 PM
sloatgnc's Avatar
Engine: 305 tbi
oh ok well thanks for all the help u guys
Old Jan 15, 2011 | 12:29 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah the Auburn has cones that wear out. What your describing doesnt sound all that bad. I wouldnt stress on it.
Old Jan 15, 2011 | 01:24 PM
sloatgnc's Avatar
Engine: 305 tbi
thanks for info
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
