manual trans in 82 camaro
Old Jan 30, 2011 | 12:05 PM
olivier.hbk's Avatar
Hi everybody
i've got an 82 camaro with 350ci(L48)and a TH350 tranny,but i planned to swap for manual
i wan't a 4 speed and i want to know what is the easyer ,the super T10,or a muncie??
Is the bellhousing for ST10 will be the same for the muncie
can i keep my th350 driveshaft?
thanks
Old Jan 30, 2011 | 02:44 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
Re: manual trans in 82 camaro
some 82 firebird/camaro came with a super T10, while the muncie and the t10 are similar, a muncie wont have provisions for a torque arm.
yes a t10 will bolt to a muncie bellhousing or vise virsa.
if you have the short tailshaft th350, the driveshaft will work
Old Jan 30, 2011 | 02:57 PM
Thank you RK82
do i really need the torque arm,if i put a muncie?
and zbar are they same for muncie an T10?
Old Jan 30, 2011 | 03:15 PM
toomany's Avatar
Yes you still need the torque arm. It's the 3rd link in the rear suspension. Probably be easiest to relocate it to the crossmember.
The z-bar and clutch should work with either trans. As long as the spline count is the same.
Old Feb 1, 2011 | 08:41 AM
A friend of mine had a bellhousing for a muncie,but i'd like to know if any bellhousing fit third gen,the TH350 that i put in fit,it's tight,but it fit!
If muncie bellhousing is not larger tan TH350 i think it's good!
if it doesn't fit i must take a ST10 bellhousing??
Oh and last questions,shifter are they same for ST10 and muncie?
(excuse my bad english,i'm just a poor little frenchie)
Old Feb 1, 2011 | 01:05 PM
Bell housings for old 4-speeds are not specific to the transmission used; rather, they are specific to the type of vehicle and the engine they came in. Thus, any BH that will fit a Muncie in any particular car with any particular engine, will also fit a T-10; and vice-versa.
A 4-spd BH "fits" in one of these cars just fine. That's not whe they can't be used.
The only stock one that will fit these cars is the one from 82 4-speed Camaro or Firebird; and it must be the correct one for the engine you have (V8, 6-cyl, or 4-cyl). Ones from other cars will not work.
Shifters are usually the same between Muncie and T-10, but they require a different "installation kit" (brackets, rods, and handle).
Putting an older 4-speed in one of these cars requires non-stock parts, that you either have to make, or buy from one of the aftermarket suppliers such as Spohn or UMI (sponsors of this board).
No 4-speed except the T-10 from the 82 cars will fit without modification, because no others have the torque arm mount.
Old Feb 1, 2011 | 02:15 PM
Thanks to all of you for helping me!!
I think i'm gonna go for a super T10,it was the easier way to have manual transmission,and all i read on this transmission is good so.... my 350ci will be enjoyable with the super T10
Old Feb 1, 2011 | 03:54 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
finding a super T-10 with the torque mount can be pretty hard, I looked for about a year, I finally found one last summer.
IMO buy one of these http://www.umiperformance.com/catalo...roducts_id=133
or if you can't afford that you can just buy the crossmember http://www.umiperformance.com/catalo...roducts_id=299
FWIW the T-10 with use the same crossmember as a TH350
Old Feb 2, 2011 | 02:57 PM
I just find one whith the torque mount,i think i'm pretty lucky
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
