Whirring noise?
Whirring noise?
Well the best way i can describe it is more of a whirring noise when i step on the gas, i'm not able to hear it when driving around town but when i start to speed up it gets louder. I put the car on park and stepped on gas but no noise so any ideas? would a bad transmission mount make a "whirring" noise? I also change differential fluid and gasket but no luck
it sounds as though it's coming from the back which is why i originally thought differential.
it sounds as though it's coming from the back which is why i originally thought differential. Joined: Dec 1999
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Re: Whirring noise?
Bad transmission mount would thump the underside under heavy acceleration- I've had that before. So definitely not that.
I would have thought that a diff noise would be more constant- whether you are on or off gas. Could be rear bearings and as you are on gas it is putting more load on them and exposing the problem.
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Re: Whirring noise?
It is a drive line issue. Could be U-joints or any bearing in the axle. Get under it and check the drive shaft first to see if there is any play.
U-joints usually squeak when they are going, whirring noises are usually differential bearings.
Oh, do you have a manual or auto? Manuals can do the same thing. Where does the noise come from, tranny tunnel area? Or towards the rear axle?
Re: Whirring noise?
its an auto, and the noise appears as though it is coming from the rear axle, it'll start up when goin maybe 30ish it'll instantly stop when i let go of the gas, also if i happen to be on a bouncy road it'll somewhat stop when the car bounces up.
yeah thats what i was thinking about differential but it had been leaking anywho, it stopped the creaking noise though
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
Re: Whirring noise?
i have the same problem and i told my auto instructer and he said it should be my spacer and my front pinion bearing and race. but for is there any oil on your rear?
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Whirring noise?
I had a WHIRRING noise before. It ended up being the needle bearings inside the U-Joint. There was little to no grease in there. I re-lubed and added some grease and the noise went away. But Bad bearings could be an issue too.
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: Whirring noise?
I have the same problem, but it's more of a high pitched moaning. It seems to come when my foot is on the gas, but as soon as I let off it goes away.
I was told the pinion bearings, but I don't know. Any ideas to what parts I need to order?
Re: Whirring noise?
thats exactly my problem!!!!!!
Re: Whirring noise?
Any ways. The reason why there is a sound while your accelerating is because of the energy or force being exerted on the culprit. As you let off the gas, there is no more pressure on the culprit, which leads me to believe that its probably the rear bearings or the U-joint. But its a shot in the dark. Could even be the axle. But for sure its behind the tranny.
Re: Whirring noise?
ohhh. You where reffering to me! yeah bro. Does the Camaro look that familiar?
Re: Whirring noise?
haha yeah dint realize that was you last time i read it, i'm prob gonna take it to the shop and just get it done. dont really have the time to be poking around especially since school started again.
sjorgens
Oct 1, 2015 07:54 PM
