New trans rebuild =FAIL
Old Feb 15, 2011 | 12:12 PM
timonator's Avatar
My son and I rebuild the 700r4 for his 86 z. It doesn't work though. Rev. is like neutral. If I put in in drive it will move forward after bringing the rpms up quite a bit. It won't upshift when moving, and 1 2 & D are like nuetral. I'm going to try doing a pressure test later but the tachometer doesn't work. Any ideas?
Old Feb 15, 2011 | 07:30 PM
daverr's Avatar
Re: New trans rebuild =FAIL
If fluid level is ok than i would pull the trans out and go thru it again. but first check line pressure since you have no engagement at all. Another possibility although sorta unlikely did you install the torque convertor all the way??
Old Feb 15, 2011 | 08:55 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
It's kind of a tough thing to rebuild. you could have messed up something in the valve body, torque converter could be bad. really hard to say. I say bite the bullet and take it to the transmission shop.
Old Feb 16, 2011 | 04:04 AM
Pro Built Automatics's Avatar
How much fluid is in the transmission and torque converter now (total)? Which torque converter did you use here? Deep pan or standard pan? DO NOT rev it up to get it to move, as this will destroy the transmission.
Old Feb 16, 2011 | 05:52 AM
timonator's Avatar
I used the old torque converter which was still full. 7 quarts put it right in the middle of the ok zone on the dipstick. Shallow pan.
Old Feb 16, 2011 | 03:53 PM
timonator's Avatar
It failed the pressure test miserably. N& low were less than 10 psi and drive& rev. Were less than 14.
Pump?
Old Feb 16, 2011 | 04:28 PM
timonator's Avatar
Is it possible that the pump mods from the shift kit could have caused this ?
Old Feb 17, 2011 | 07:21 AM
timonator's Avatar
Boost valve was in the pan. Can't find c-clip.
Old Feb 17, 2011 | 10:23 AM
timonator's Avatar
C-clip was in the filter. Trans appears to work properly now.
Old Feb 17, 2011 | 01:22 PM
I've seen this many a time, good thing it was simple.
hectre13
Dec 11, 2023 08:14 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
fbirdroller
Sep 2, 2015 10:27 PM
djmarch
Aug 10, 2015 08:42 AM
hokis
Aug 9, 2015 03:57 PM
