Problem with TH700 R4
Old Feb 16, 2011 | 01:36 PM
Teod83's Avatar
Car: '91 Pontiac Firebird
Hi! I have a problem... I broke this piece:
And so it loses oil and the car (84 Trans Am) doesn't change gear. The problem is that I don't know what is the exact name of this piece and therefore don't know where i can buy it!
Can anyone help me? Thank you!
Old Feb 16, 2011 | 02:27 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: Problem with TH700 R4
Reverse input drum. Check bulkparts.net
Old Feb 16, 2011 | 02:28 PM
tcgmac's Avatar
Car: 88 iroc
Engine: 350 bored .40 reman vortec heads
i think that might be the sun shell not sure?
Old Feb 16, 2011 | 03:26 PM
Teod83's Avatar
Thanks guys. is the reverse input drum. Now I'll try a vendor with a fast shipment to Italy. Thanks again!
Old Feb 17, 2011 | 12:33 PM
Pro Built Automatics's Avatar
They rarely crack, but burn where the band rides like yours here. Your 1-2 shift must have been pretty bad. Make sure you get a oem drum as the aftermarket ones are not flat where the band rides, but convex. A good used drum will work here, it just must flat where the band rides.
Old Feb 17, 2011 | 12:56 PM
Teod83's Avatar
I found an original used here in Italy. It seems in good condition. Now I'll try to use that and meanwhile I'll get a new one. Thanks for the advice!
Old Feb 17, 2011 | 03:39 PM
Just make sure that it is flat where the band rides and you will be ok. You will not need a new one.
Old Feb 17, 2011 | 03:56 PM
Teod83's Avatar
I should not need it, but because here in Italy there are few spare parts is always better to have a spare so you will not have to wait for the shipment of a new one.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
