entire rear end swap
Old Mar 6, 2011 | 07:27 PM
the rookie24's Avatar
Car: 1992 rs stock for now
Transmission: auto
i have a 92 rs with drum and i have a entire 88 roc rear end with disc what exacty do i need and what needs to done to swap the rear ends i heard something about a porpatinal vale and the brake booster not sure please help
Old Mar 6, 2011 | 07:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: entire rear end swap
Some folks swap proportioning valve for one from a rear disc car to keep the right proportion of brake fluid pressure to front/rear as it should be. Alot of folks don't bother and don't have any issues. I think that the rear disc brakes require less pressure than a rear drum brake to get the same stopping power - worse case scenerio is that you'll mash the brake in an emergency and the rears will lock before the front - which is good - locking fronts means no steering.
No need to change booster. Swap that sucker in there! Probably has better gears and posi as well if it's a disc brake rear!
Old Mar 6, 2011 | 07:52 PM
Transmission: auto
yea its 3.27s posi all right how are the brake lines that come from the body do those hook straight up to the rear since im goin from drum to disc
Old Mar 6, 2011 | 08:14 PM
Car: 1992 RS
Engine: Carbed 350
Some do, some don't - there are some differnces is brake line fiting sizes over the years - worse case is that you have to cut the end off with a small pipe cutter, add the right size fitting one side or the other, and reflare it with a flaring tool.
Old Mar 6, 2011 | 09:12 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Master, no. For best brake performance, use the appropriate combination valve as there are different biases. More info can be found in the FAQ:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 7, 2011 | 06:12 AM
Transmission: auto
thats for 10 bolts the 88 rear end is a 9 bolt the one in 92 im pretty sure is a 9 bolt too? confused
Old Mar 7, 2011 | 06:49 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You are swapping in a 9-bolt. So you will need the Proportioning valve and the Parking brake cables.
Old Mar 7, 2011 | 06:50 AM
JamesC's Avatar
The braking systems between the 9- and 10-bolt are the same. If the rear in the 92 is a 9-bolt, it isn't original to the car.
JamesC
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
