T56 flywheels for older 2 piece rear seals
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
Hi For those that have an older block and installed a 6 speed tranny I was Wondering your thoughts on which works the best.
There are 3 companies that I know of that make a flywheel to bolt the 93-97 LT1 T56 6 speed tranny to an 85 an older block w/ the 2 piece rear main seal.
Centerforce Steel flywheel 700107 $425
Ram aluminium 2555 $408
McLeod 64033-00-07 $ not sure this is the correct #.
I would think go aluminium, but not sure...
Thanks in advance!
Thanks in advance!
Car: 1990 camaro RS
Engine: forged 383,8.7;1 200hp nitrous
Transmission: t56 6 speed
Axle/Gears: quick perfomance 9 inch with 4.11s
Re: T56 flywheels for older 2 piece rear seals
what are your plans for the car? daily driver or strip only?
if you want it streetable i liked the centerforce because its weight keeps momentum up. the aluminum will allow you to pull RPM much faster but is to to good for the street
Received 1,697 Likes
I have the CF.
It's HELLA heavy. It makes the engine NOTICEABLY more sluggish revving than the stock 305 one I had on it before. That might be OK in some situations but I don't think it's necessary in mine.
If I had it to do over, I might use an aluminum one.
If you have even worse (lower number) gears than my already pitiful weenie stock ones (3.73) as I suspect you do with that 9-bolt, you will probably want the heavy one because the engine RPM will be held so low all the time. OTOH if you have gears that are a better match to the T-56 to begin with such as 4.10, the aluminum will probably be better.
Thanks, appreciate the feedback.
I plan for a daily driver.
I have come across another made by Spec and its much cheaper
Steel: SC66S = $279 (NY Performance Shop) $359 on their site
Aluminum: SC66A $ $359.00 on their site
The cool thing about this is that is has a weight that you can add depending on how the motor is balanced.
From what I was told (same as above), its better to go with steel for a daily driver as the alum. doesn't hold the momentum/power of the motor due to less mass.
I'm not sure what gear ratio I have, it did rev high on the highway w/ the 700R4 - 70MPH =2750RPM
Thanks! I think I have some pics of the gear codes, when I changed the axle bearing...just have to find them.
Im in this delimma right now. My build got switched up to now include a T56 that I couldn't pass up. Includes a VERY good Spec 3 clutch(know this as my friend and I put it in for the guy), but no flywheel.
700rwhp TPI car with a Vortech SC..... centerforce one?
Oh yeah, my car has 2.73 gears and 27" tall tires on 19" wheels. I'll never get to use 6th until I change gears!
Car: 1990 camaro RS
yeah you are definitely going to want those gears changed. gas mileage will go up but you will have a large power decrease. i actually have a couple of the centerforce flywheels left over . mine is the 9 bolt with 3.45 and it is a pig
Thanks!
Car: '89 IROC-Z
Engine: StealthRam 355
Transmission: 6-speed
Axle/Gears: 3.70 9-bolt
I've been running the Centerforce flywheel and Spec clutches for 8 years. I started out with a stage 3, but decided to drop to a stage 2 when I pulled the powertrain to swap it into another car. The stage 3 was just a little too much for me in a street car and had some mild chatter at low speeds, more so when backing. I have NO complaints with the stage 2 in a 375ish HP street car. The flywheel is indeed VERY heavy and no-load revving is a little more sluggish than I'd like, but I don't run around kicking the throttle all the time anyway.
Also FWIW I run a 3.70 9-bolt in the rear and turn around 1800rpm in 6th at 80mph. The majority of 9-bolt rears were equipped with 2.77 gears, and if that's what you have they'll make you miserable. I had a peg-leg 2.73 10-bolt behind my T56 for the first six months or so and it was truly a dog. 6th gear was essentially unusable.
Car: 1990 camaro RS
im running a stock clutch now which i could truly do without i am looking into a ram clutch ive heard some good about them for there price just need to come into some more cash. im also working on swapping a forth gen 10 bolt posi with 4.10 here in the very near future
Car: '84 Z 28
Engine: has 8 cylinders
Transmission: has a stick coming out of it
Axle/Gears: a grenade, makes wheels turn
if you plan any track time its best to use the steel flywheel, if its all street driven then the aluminum will be ok..
Car: '89 IROC-Z
The concept is still applicable...only the part numbers are different.
In my experience, aluminum flywheels are best suited to autocross and rally racing where there are a lot of sudden gear/rpm changes and the engine needs to be able to rev up and down quickly to accommodate that. For drag racing or a street car, there's no real need for a lightweight flywheel, and using one could make it more difficult to get a good idle quality out of the engine.
Anyway Ram said they have sold many for street apps and they haven't had one come back, zero issues....
Think I'm going w/ the Spec steel FW.....
