Speedometer question...
Old Apr 10, 2011 | 11:50 AM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
Transmission: TH700R4
I swapped my rearend from 2.73 to 3.23. Which parts will i need exactly to match my speedometer. Drive gear ? Driven gear ? Vehicle Speed sensor ? Which colors of gears ?? My tires are 245/50-16
Thanks a lot !!
Old Apr 10, 2011 | 12:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Speedometer question...
you need to replace the drive and driven gears. i dont have the chart handy, so i cant tell you the colors, i got them here years ago
your current sender is fine.
here
http://www.transmissioncenter.net/sp...n_______va.htm
looks like 18 tooth drivegear(blue) 45 toothdriven (light blue)
Old Apr 10, 2011 | 01:11 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Mine had the red drive gear from the factory, so i used the dark gray 44T driven gear, to go from 2.73 to 3.23. (16 in crosslace)
Old Apr 27, 2011 | 05:13 PM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
Now, i bought the 44 tooth driven gear but it doesn´t fit.. I can´t understand, how can you use it ?? thx
Old Apr 27, 2011 | 05:23 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Thanks a lot !!
GM used 15/40 or 17/45 with 3.23 gears / 700-R4 / 245/50R16.
The sticky at the top will give you different information.
As far as I know, the VSS gears only go up to 44 tooth.
Old Apr 27, 2011 | 06:49 PM
thomas1976's Avatar
Car: 91 Trans am
From the 92firebird GM service manual:
P245/50ZR16 with 2.73 axle ratio, use BLUE 38 teeth driven gear and RED 17 teeth drive gear.
P245/50ZR16 with 3.23 axle ratio, use DARK GREY 44 teeth driven gear and RED 17 teeth drive gear.
If it doesn't go in, something is wrong or done wrong (the concave part faces the VSS).
Old Apr 28, 2011 | 10:44 AM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
Perhaps, my car has another vss than your 92´f-body ?! My driven gear is red and the drive gear is red, too. Stock with the 2.73 rearend..
Old Apr 28, 2011 | 10:50 AM
jmd's Avatar
jmd
colour varies; always go by tooth count.
Old Apr 28, 2011 | 11:01 AM
thomas1976's Avatar
Car: 91 Trans am
That is possible, I only dealt with 91-92 camaro/firebird VSS sensors.
They look like this http://www.rockauto.com/catalog/moreinfo.php?pk=343809
Old Apr 28, 2011 | 02:59 PM
88´TransAM's Avatar
Car: TransAM
Engine: 355SBC
Oh no... it´s true. My vss doesn´t look like yours..
It´s the better way to go just with new gears or with this sensor from the page ?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Bigold4x4
Sep 28, 2015 05:21 PM
