T56 gear shifting without clutch?
Old May 20, 2011 | 11:01 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Can you shift gears in a T56 without depressing the clutch?
I had a T56 rebuilt by tickshift performance. I installed it and hooked up hydraulics but havent finished my build yet and there is no fluid in the trans yet either.
I was installing the clutch linkage and trying to set the pedal position. I depressed the pedal as far as i could with my arm and shifted gears just fine. I let go of the clutch pedal and found that i could still shift between gears without too much effort.
Is something wrong with that? Is that only because i havent run the transmission yet? Just want to make sure.
Old May 20, 2011 | 11:44 PM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Re: T56 gear shifting without clutch?
Most manual trans can be shifted threw gears when not running with out clutch i wouldnt worry to much about it till u you have everything up and running and then try it
Old May 21, 2011 | 07:08 AM
Car: 1992 z28
Ok, thanks! figured it was just a mattering of not running yet.
Old May 21, 2011 | 05:02 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
You can shift the T56 without the clutch while driving it too. Any synchronized tranny can be shifted up or down clutchless without grinding.
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
86White_T/A305
Aug 17, 2015 12:16 AM
tnrednneck
Aug 13, 2015 08:57 AM
hokis
Aug 9, 2015 03:57 PM
