One Trans lines to radiator?????
Old Jun 16, 2011 | 09:32 PM
GeorgiaSS's Avatar
OK, I know this can't be right. I just picked up a 86 iroc that has been converted to an older 350 with a carb.........Had it towed home this afternoon, while looking at what all I have to fix I noticed there is only ONE line from the trans going the radiator. The other hole in the radiator has been plugged off. I know the fluid has to be cooled thru the radiator then flow back to the trans. The car has been sitting for almost 2 years, the son of the guy that owns the car said after they drive a little while the trans stops working. WTH?
Old Jun 16, 2011 | 09:58 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: One Trans lines to radiator?????
Is that line even connected to the tranny lines? sometimes people will bypass the radiator transmission cooler for an external cooler sometimes help on with the zipties thru the radiator fins. That's probably what the owner of your car did.
Old Jun 16, 2011 | 10:02 PM
GeorgiaSS's Avatar
Never got under the car today. I'll crawl under it tomorrow. Didn't think about them by passing it. Thanks...
Old Jun 17, 2011 | 04:46 PM
GeorgiaSS's Avatar
Got the car running today, put it in drive , nothing in any gear. Fluid is pink. Radiator may be screwed up, letting water leak into the trans fluid so that might be why they by passed it.
Old Jun 17, 2011 | 09:50 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
But did they unhook both lines or they left the return line and connected the pressure line? even though thier both under pressure technically...weird. a radiator is cheap change it out!
Old Jun 17, 2011 | 10:15 PM
GeorgiaSS's Avatar
Put it up on jack stands this afternoon and pressure wash the bottom of the car. I'm going to change the fluid tomorrow and check the lines.
Old Jun 18, 2011 | 08:58 PM
GeorgiaSS's Avatar
Trans pan.. Doesn't look good.
Old Jun 18, 2011 | 08:59 PM
GeorgiaSS's Avatar
the other
Old Jun 18, 2011 | 09:12 PM
GeorgiaSS's Avatar
Found this too.
Old Jun 19, 2011 | 01:24 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
I have no idea about any internal transmission components. although I know thier are springs in there.
Old Jun 19, 2011 | 03:59 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
That is the 1-2 accumulator spring that is broken,maybe I think from the fuild color that the radiator is leaking into the cooler side on the radiator
Old Jun 19, 2011 | 08:50 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah that is what it looks like (the fluid anyway). Change your radiator. I guess its possible if the car was sitting it could have gotten water in it but not too likely....
Old Jun 21, 2011 | 10:25 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Rebuild the transmission, too. Coolant is death to the clutches.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Reddeath210
Oct 6, 2015 08:20 AM
