700R4 question
Car: Camaro RS
Engine: TBI 305 H.O
700R4 question
I have been trying to put a ls6 corvette engine in my camaro for a while now and have been thinking of way to do it but save some money here and there and i was wondering I have seen 700r4s being able to handle up to 600 hp with out any failures Ive been trying to find a good rebuild kit to make mine be able to handle that much beacause the new engine is going to have 525 hp and 685 torque so i dont want anything to snap free thanks
Guest
Posts: n/a
Re: 700R4 question
None of the "kits" include everything necessary, because to get that strength seems to require some machining. Even the "race" kits with the good parts.
Yes, you need the Alto Red Eagle stuff, but you also need "The Beast" sun shell? and the 5-pinion planetaries, and billet servos, and more.
The only "cheap" way to transmit that much torque is a TH400. And that brings costs of it's own.
The only cheap option is to forget the power adder, and just leave the LS6 at the 400 HP level.
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: 700R4 question
Talk to Dana at. WWW.pro built.net he can build them to handle whatever power you put out.
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: 700R4 question
X2 for Dana at Probuilt. www.700r4l60e.com Check out the 700r4 pro street or pro street elite kits.
Iroc8t8
Aug 26, 2015 08:14 AM
