Towing of a MT, '90 RS
Old Jul 5, 2011 | 06:47 PM
wcolvett's Avatar
Hello,
I used to lurk around here because I'm just a fan of the Camaros, had a '73 a long time ago... Now, I have the opportunity to pick up a '90 RS w/T-Tops, 5 speed, and 305 TBI... Thing is, it's in another town and currently won't start (cranks but won't turn over, I assume ignition or fuel), so it'd have to be towed. It's probably about 35-40 miles from here so hiring a tow truck would be half the cost of the car, so it isn't going to happen. I am considering just renting a 2 wheel car dolly to tow it with my Ram 1500, but I wanted to see if someone could answer a question for me... I know the rule of thumb is not to tow a car (mainly AT) for more then a short distance on it's drive wheels w/o disconnecting the driveshaft. On this car, would it be safe in neutral to tow it that distance on the rear wheels w/o dropping the driveshaft if it's (obviously) in neutral?
Any advice appreciated,
Warren
Old Jul 5, 2011 | 09:47 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Towing of a MT, '90 RS
i have done it . i needed some sections of 2X8's to prevent damage to GFX when loading on dolly . just take care & be safe . good luck .
Old Jul 9, 2011 | 09:08 AM
Pocket's Avatar
Car: 91 Trans Am
Unhooking the DS isnt hard, why on earth would you risk it?
Old Jul 9, 2011 | 09:28 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
I rented a car trailer from U-Haul last month. I returned it the same day and it was $54. Have a buddy help you push it up there or use a come along and then you don't have to disconnect anything.
Old Jul 9, 2011 | 10:04 AM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
You can tow a man trans car w/o unhooking the shaft with no problem since there is no pump in the trans like a AT car. If it was me I would unhook the shaft to be 100% safe.
Old Jul 9, 2011 | 12:39 PM
problem2420's Avatar
Car: 86 ta
Engine: 305tpi
Transmission: t5
Axle/Gears: 2:77 soon to be 3:42
towed my ta but then again it didnt have a transmission, but i also towed a 95 ta manual no problems except for a flat tow dolly tire. and yes some 18-28" 2x6 would be helpful because these cars are really low.
Old Jul 9, 2011 | 02:56 PM
rdhanded2's Avatar
Top Answer: 1
It is only a $10 difference between the car dolly and full trailer. A lot easier to not have to get under it and disconnect anything, and just use a full trailer. My
S10K20
Oct 7, 2015 06:45 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
thekurlyone
Sep 30, 2015 12:54 PM
dimented24x7
Sep 17, 2015 06:58 AM
TBRays98
Sep 6, 2015 05:05 PM
