Need Help with TH700
I have a TH700 transmission from my old '87 chevy pickup and I have put it in my '72 chevy pickup with a 350 motor, but it won't shift only have reverse and 1st gear, any ideas on what it could be? It worked fine in when I took it out of the '87.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Need Help with TH700
You connected the TV cable up correctly and set the adjustment on it? www.thirdgen.org/detent
Just a guess, but I had this happen after a hard shift from 1st to 2nd years ago. There was a plastic gear in the back of the 700R4 that had broken. IIRC, there is a round cover on the back to pry off, and check. See if that plastic gear is broken...
GTAsweden
Jan 20, 2007 01:00 PM
PerthZ28
Dec 31, 2006 11:29 AM
FastBroker
Oct 18, 2000 08:10 AM
1983, 1st, 34l, 53, adjustment, cable, camaro, chevy, gear, noise, passing, reverse, th700, transmission, troubleshooting
