T5 speedo gear ?'s
Car: 85 Trans AM
Axle/Gears: Moser 12bolt/3.73 truetrac
T5 speedo gear ?'s
I've got an '85 Trans am that has a T5 tranny and I swapped the 9bolt BW out that had 3.27 gears with a moser 12bolt that now has 3.73's. I read the stickys about the speedo gears and so forth, and figured out i actually need a 20 tooth driven gear with the 3.73 gear ratio and the current tire size I'm running now. My question is do I have a mechanical or electronic speedo? The parts guy at the dealer said i need a 140..... something part number, but I was thinking it was the number 3987920??
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 85 Trans AM
Re: T5 speedo gear ?'s
That's what I was thinking it being mechanical. I'm confused as to which driven gear it actually needs. Do I need the gear with the plastic shaft or the one with the metal shaft? How do I know which one? Correct me if I'm wrong, but is the 3.......series part number the plastic shaft and the 14......series number the metal shaft?
Car: `86 SS / `87 SS
The 20 and 21 tooth gears with metal shaft are discontinued, so plastic it is.
Car: 85 Trans AM
Car: 1988 Pontiac trans am
Car: 85 Trans AM
Your old speedo gear sleeve might work fine w/ the new gear.
New ones are steel and have a seal that may need pressed inwards to meet the sealing surface on the new gear.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
