700r4 trans cooler lines install
Old Sep 24, 2011 | 01:24 PM
husker2733's Avatar
Car: 1983 Trans am ws6
Engine: 305 HO
Transmission: wct5
Im installing the trans cooler lines on my transmission, and im having some troublle getting them routed right. is there any tricks on making this easier. thanks,Eric
Old Feb 7, 2015 | 02:58 PM
uscgsoldier4's Avatar
Car: 1992 Pontiac Firebird Formula
Engine: LB9 305 Tpi
Axle/Gears: Stock Gears
Re: 700r4 trans cooler lines install
Dammit the one thread that someone is having the same problem as I am, no one replied. Did you happen to figure it out? Im lost!
Old Feb 16, 2021 | 12:51 AM
calidude's Avatar
Car: 1985 Camaro IROC
Transmission: Auto O/D
Bump as also looking for guidance
Old Feb 16, 2021 | 12:09 PM
OrangeBird's Avatar
Car: 1989 Firebird
The reason it's such a PIA is that when it was being built the lines were fitted to the engine and transmission before they went into the car .
I have no advice beyond removing as many things that are in the way as are practical to remove, and then a little careful bending and a lot of patience.....
Old Feb 16, 2021 | 12:33 PM
calidude's Avatar
Thanks for the guidance and heads up, yeah I ordered a set from Inline Tube as the upper line is cracked at the radiator... I'll have a go at it but looks like a fun job
If I discover any strategy will share for future reference
Old Feb 16, 2021 | 12:42 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
yea, its really just one of those basic-yet-difficult tasks. the angles to use your fingers and tools are challenging, the space in the trans tunnel is tight, and making sure not to cross thread them while frustration grows is a problem.
Old Feb 16, 2021 | 12:54 PM
calidude's Avatar
makes sense and appreciated, I procured a SK Tools 1/2" crows foot flare nut wrench and looks like using it with a wobble extension will help... will probably have to practice and step away as needed
Old Feb 16, 2021 | 07:09 PM
Biggest problem I always had with those, in lots of chassis, was near the engine mounts. Sometimes the only solution was to remove them before the lines would go in.
Old Feb 16, 2021 | 07:47 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Really wasn't too hard when I did mine about 6 months ago. A hassle, yes, but not a nightmare...
Old Feb 16, 2021 | 11:37 PM
calidude's Avatar
Thanks guys as hope it goes well the upper line is cracked on my 85
Old Feb 17, 2021 | 04:12 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
You dont need to use hard lines for the transmission FYI, plenty of companies sell SS/rubber flex hose that will work just fine
Old Feb 17, 2021 | 01:43 PM
calidude's Avatar
yeah, trying to keep it as stock as possible and stay with hard lines
Old Feb 17, 2021 | 07:35 PM
That, you could cut off and flare the one line down below there somewhere; do the same to a short stick of 5/16" brake line from around the corner; bend it up nice with a tubing bender; use a flare union; and thereby just replace the fornicated portion. Leave the rest alone.
Get a radiator while you're at it and do away with that crusty skanky leeeeeeky thing in those photos.
Old Feb 17, 2021 | 10:50 PM
calidude's Avatar
Lol fornicated portion?
Yeah I was thinking the same and then figured in I don't have a bender, flare tool, and parts for a union got me to dang near the same cost or more as the prebent tubes are $45.
The heater hose above was leaking, radiator seems okay but I haven't started it yet as been sitting since 1996 and was planning to switch out the hose and flush everything. I was turning the motor over and this started spewing trans fluid.
Old Feb 18, 2021 | 02:20 PM
The thing about tools is, you get to use them more than once. (if you buy good ones) Which means as soon as you discover the next thing that needs a piece of tubing, you're already there; and the tools start making you money instead of costing you. And like it or not, there always seems to be a "next thing".
The most expensive piece will be the flaring tool. You'll want one that can do a double flare. Next most $$ will be the bender. You can take a look at Home Depot etc. and price them out. The line, union, and cutter are pretty cheeeep comparatively..
Old Feb 23, 2021 | 02:02 AM
calidude's Avatar
Flared something up and then the lines came in the mail.
actually pleased with how this turned out though and was good learning to bend and flare
Old Feb 23, 2021 | 10:16 AM
SKFengineer's Avatar
Car: '87 IROC (TPI 350), '01 Corvette, '
Engine: '90 Corvette 350, blueprinted and b
Transmission: 700 R-4, with stage 2 shift kit
I have my engine out right now and I was looking at the lines thinking about replacing them... Seems like a good call on my 34 year old IROC. I also plan to update my aftermarket, 2nd trans cooler during this time.
Good luck to all and nice work on the fix Calidude, if that is your first time it's nice and neat.
Old Mar 30, 2021 | 11:03 AM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
Do you happen to know what the thread is on the radiator? And if it happens to be the same as the lines where they go into the transmission?
Old Mar 30, 2021 | 11:15 AM
Yes the fitting is the same at both ends, since the tubing is the same at both ends; 5/16" inverted flare. Can't recall off the top of my head what the threads are for that fitting but it doesn't matter, because all 5/16" inverted flare fittings have the same thread. 5/16" inverted flare is all you need to know.
There's an adapter that screws into the case that's some other thread but I don't know what that is. It shouldn't be a concern though unless you've destroyed the threads in teh case somehow, which although no doubt possible, is not likely.
The repair in the photo looks pretty decent actually. I've seen FAR worse attempts at a "fix" than that one. The tubing is just a little bit flattened but probably still works fine.
Old Mar 31, 2021 | 02:20 PM
y5e06's Avatar
Car: itsa '85 LG4 S/E Turd 'Bird
Engine: Wheezy 305
Axle/Gears: 10Bolt, 3.42s, TruTrac
pretty good repair. done the same many times. but instead, to make it easier I just run only about 6-12" of new hard line then use proper trans hose for the middle of the span toward the other end. easier to get the hardlines in a good position and the length isn't critical.
you can use your flaring tool to create a 'bead' or ridge on the end of the line for the hose & clamp. Just only do the 1st part of the double flare where it bulges out some, but not too big a bulge. And, don't do the invert-the-flare part.
Smokin87TA
Mar 21, 2006 02:45 PM
PRoth
Jun 6, 2005 06:09 PM
TheWraith
Sep 6, 2001 01:11 PM
