Which ujoint is better?
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Well iv finally had enough of the clunking when I put my car into gear or change gears. After looking around I found it could be either my ujoint or my tranny mount, I changed my mount and while it did help but not enough so when I checked my ujoint it's stiff and it looks factory so it's time for a new one or atleast new grease. But what ujoint is better and joint to last me along time? Autozone has 2 one with a grease insert and one that's suppose to be maintaince free. Which is better?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Which ujoint is better?
OEM u-joints are non greasable. From a performance standpoint, a non greasable u-joint is strong because it doesn't have the zerk fitting. For a long life u-joint, it should have a zerk fitting and you should grease it at every oil change just like you should be doing to all your steering and suspension components.
I tend to stay away from house brands. Although they're inexpensive, they usually don't last very long. Buy a Spicer u-joint.
Engine: L31 350
didnt check this before i made my way to autozone and just followed my dads advice and got the duralast red ujoint with the grease fitting. its just behind my v6 and i rarley put my foot in it so im hopping i should be ok with this one. i got the 2 year warrenty with it.
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Engine: L31 350
I hope I'll be fine and no this is my first ujoint but my dads helping me who was a mechanic for several years but I forgot I had 2 ujoints so I need another ujoint now
ambainb
Apr 25, 2016 09:21 PM
jaygt
May 5, 2009 07:24 AM
Trevor K
Feb 8, 2006 09:06 AM
