is my torque converter bad?
Old Oct 11, 2011 | 07:13 PM
dvdlovesbball's Avatar
Car: 1987 iroc-z
Engine: 5.0 305 carb
Axle/Gears: stock 10 bolt
i have a 700r4 transmission and everytime that i put the transmission into gear ( reverse or drive) it drops the engine rpm by about 500. i have to have my idle set at 1200 to compensate for this. also when i put it in gear the car jerks back. one of my friends said its a torque converter is that true?
Old Oct 11, 2011 | 07:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: is my torque converter bad?
What are you using to measure engine speed?
Old Oct 11, 2011 | 07:46 PM
Car: 1987 iroc-z
my stock tachometer
Old Oct 11, 2011 | 07:52 PM
88transam 88's Avatar
Car: 1988 TransAm
Engine: sbc 9:8:1 cr 40os slugs rhs heads
Transmission: th400 3800stall b&mkit manual vb
Axle/Gears: stock
Is it makeing nose when u drive
Old Oct 11, 2011 | 07:54 PM
Car: 1987 iroc-z
no it runs perfect besides that issue. no noises, shifts perfect.
Old Oct 11, 2011 | 08:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Originally Posted by dvdlovesbball
my stock tachometer
Which is probably reading high like most of them do at this age. Check with a test instrument.
Old Oct 11, 2011 | 08:39 PM
Car: 1987 iroc-z
ok but why does it jerk into gear?
Old Oct 11, 2011 | 11:53 PM
affliction1's Avatar
Car: 89 chevy camaro rs
doesnt sound like its in the trans,youll know if any thing goes wrong with trans,by checking the fluid,as long as your level is good and fluid isnt burnt or have metal flakes in it you should be fine,the jerk is from the over compesiation,setting the idle that high is like neutral droping it
Old Oct 12, 2011 | 05:11 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
It jerks into gear, cuz you're idling at 1200. The 500rpm drop is most likely a tuning issue, either timing or fuel.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
redmaroz
Apr 25, 2017 07:14 AM
xxx3man`
Sep 23, 2015 10:37 PM
gwade12
Aug 8, 2015 08:17 AM
