700r4 problem after rebuild
Old Nov 6, 2011 | 06:42 PM
migman's Avatar
Car: 89 camaro
Engine: 383
Axle/Gears: 10 bolt posi
after rebuild 700r4, rpm seem to vary a little bit in third gear while holding throttle steady. transmission seems to tremble a little bit. I added a corvette servo .500 boost valve and a high pressure spring. I removed the check ball from the end of the input shaft but left the capsule and removed the check ball from the rear of the case I believe it feeds the low-reverse piston. I also removed the bigger check ball from the valve body, left out the 3-4 load release springs and drilled the hole in the spacer plate like the atsg manual says. It also seems to shift into 3rd to early.
Old Nov 7, 2011 | 03:10 PM
migman's Avatar
Car: 89 camaro
Engine: 383
Re: 700r4 problem after rebuild
Uptade: I found that trembling wasn't the trans, I had a broken spark plug only the boot was holding it together. Still seems like its shifting to third to soon and it is definetly taking off in second gear, I have to manually pull it into first. Any ideas on what could be causing this?
Old Nov 10, 2011 | 11:59 AM
migman's Avatar
Car: 89 camaro
Engine: 383
I pulled the governor yesterday and its not sticking I also tried adjusting the tv cable again, it is still shifting to soon and taking off in second.
Old May 25, 2012 | 07:50 AM
b18c1355's Avatar
2-4 band stuck on wont let go until 3rd comes? check servos. maybe servo check ball probelm? that, maybe. its been a while. u might of fixed it already. id like to know what it was
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Infested
May 22, 2018 11:56 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
formula_novice
Aug 18, 2015 08:48 PM
hokis
Aug 9, 2015 03:57 PM
