87 irocz transmission fluid help.
Car: 87 irocz 305 5.0 5 speed G92 option
Engine: 305 tpi
Axle/Gears: 9 bolt 3.45 factory gears
Hey guys was wondering if you knew what kind of transmission fluid to put in my 87 irocz camaro 305 5.0 standard transmission? Just got it and I wanna change the fluid 130xxx original miles.
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: 87 irocz transmission fluid help.
Every T5 I've seen has had ATF in it, including the earlier NWC design. I have ATF in mine.
Engine: 305 tpi
Sweet man thanks I'm gonna look into that. I aprreciate the help.
Engine: 305 tpi
Isn't lb9 refering to the type of transmission I have?
Engine: 305 tpi
Atf is for automatics? Mines a stick shift.
Car: 1990 Firebird
Engine: 350 TBI
Engine: 305 tpi
Hmm. Ya pretty new here thanks man. I will definately look into those.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Engine: 305 tpi
So my 87 305 too Irocz has a T5 transmission for sure? as long as its the original.
Engine: 305 tpi
Also how can I tell if its world class or non-world class?
http://lmgtfy.com/?q=world%20class%2...identification
Third link.
And use ATF, that's what your transmission was designed for.
PS: Learn to use the search feature... Almost every question you could ever ask, has already been asked and been answered before.
Third link.
Engine: 305 tpi
Cool man thanks so much! Ya I will definately use the search feature. I appreciate your guys patience. I'm not a gear head my dad is teaching me... Again thanks everyone. I'll try not to post dumb stuff and search before I post Haha.
Engine: 305 tpi
So my dad and I drained the transmission and he said it smelled like gear oil. Said he'd be able to recognize when we drained it. I told him that I had read that that it would shift smoother with atf so that's what were going with.
Engine: 305 tpi
Valvoline dexron is what we got.
Car: 1986 Firebird
Engine: 5.0L V8
considering ATF is mentioned in this thread lol... My dipstick says to use dex II but the computerat work says to use dex VI. What should I use? D:
Engine: 305 tpi
I used VI seems to be holding up fine.
