T56 Swap hydraulics
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
T56 Swap hydraulics
If you have a car that was originally a T5 car, do you have to swap the hydraulics over to that of a 4th gen? I understand that the "hose" from the master to the slave is not bendable and needs to be turned around, but has anyone tried to use the stock components and replace the hose with a longer bendable type?
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Re: T56 Swap hydraulics
No you should not have to change the master or the slave. Just replace the line with a steel braided AN-4 hose. McLeod Clutches offers a AN-4 hose in whatever length you need and a roll pin to AN-4 adapter fitting to plug into both your slave and master cylinder. The part number to the fitting is 139026.
Car: 91 Firechicken
Engine: 355ci SBC
I actually went down to my local hydraulic hose shop today and showed them my situation. Evidently, you can take the hose off the stock barbed fittings and replace it with some bendable line they have that is similar to what they use for air brake lines or air ride systems. Supposed to be compatible with hydraulic fluid and able to withstand 300psi. We'll see. Worse case, I have to spend more money. This stuff was 31 cents a foot.
Car: 91 Firechicken
Engine: 355ci SBC
Here's another question. I have a QM 3 disc that I really wanted to use with my swap, but beings how they're different styles, I'm screwed.
...or am I?
http://www.summitracing.com/parts/RAM-78140/
What you guys think about this?
...or am I?
Car: 92 Z28 Camaro
...or am I?
...or am I?
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I just bought a GM hydraulics assembly for a 93-97 manual car and bolted it in.
The only problem is the eyelet on the master cyl rod is too large for our clutch peg. You'll have to come up with a way to make a bushing to fit it.
Car: 92 Z28 Camaro
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
i just did this weekend and it works great thirdgen master and 4th gen hydraulic throwout bearing
Car: 91 Firechicken
Engine: 355ci SBC
Soo...has anyone used the part I listed?
Car: `86 SS / `87 SS
More reading / links.
https://www.thirdgen.org/forums/tran...inder-t56.html
https://www.thirdgen.org/forums/tran...ne-repair.html
So yeah, your question has been addressed recently, but it's spread across a few threads.
Car: 91 Firechicken
Engine: 355ci SBC
...or am I?
...or am I?
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
