trans cooler
Old Nov 27, 2011 | 03:06 PM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
trans cooler
i am looking to get a trans fluid cooler on my car. i have a 383 stroker with a turbo 350 trans with like a 2600 stall im just wondering what size i need to get to properly cool the fluid and if there is any other place that would b good to mount it other then in front of the radiator
Old Nov 27, 2011 | 03:21 PM
Twin_Turbo's Avatar
Re: trans cooler
Old Nov 30, 2011 | 06:32 PM
Car: 89 iroc
Engine: 355tpi
Re: trans cooler
anyone on the sizes?
Old Nov 30, 2011 | 08:26 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: trans cooler
I run an 11x12" Long Tru-Cool LPD cooler in front of the radiator (small air gap between transmission cooler and A/C condenser). I find it works well because at slow speeds, the radiator fans will pull air through it. The A/C still works great since the cooler isn't attached to it. And the transmission runs nice and cool in Texas weather.
I run it with the radiator cooler bypassed for extra cooling performance.
I can still run it fine in the wintertime because the LPD will bypass the cooling area of the transmission cooler until the pressure (heat) comes up enough to warrant it running in it's normal mode.
Old Dec 1, 2011 | 02:39 PM
Car: 89 iroc
Engine: 355tpi
Re: trans cooler
thanks for the info
Old Dec 1, 2011 | 09:24 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: trans cooler
Delete
Old Dec 1, 2011 | 10:17 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: trans cooler
If you're not running AC, use an 88-92 condensor.
Old Dec 1, 2011 | 10:19 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Re: trans cooler
I have a B&M Supercooler #70268 with a Derale fan mounted in front of the radiator. The Supercooler is 7.5 x 11 x 3/4. $55.96 @ Summit Racing.
Old Dec 6, 2011 | 06:13 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: trans cooler
I bypassed the rad cooler and have a 8x11 cooler with an electric fan on it with an external filter with a mobil one filter. Every 10 degrees you drop your temp you add 10.000 miles to your trans. I made an aluminum air dam that is three inches lower to grab more air to keep mine cool. It is also curved slightly forward to grab and direct the air. Be sure to remember to use transmission line hose and not fuel hose.
Old Dec 6, 2011 | 07:00 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: trans cooler
i couldn't find a good place to put my b&m trans cooler in front of the radiator.not much room up there.pictures would be nice.
deracer
Apr 11, 2016 12:04 AM
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
