buy complete ls1 or build it
Old 11-30-2011, 03:42 PM
cphgncowboy's Avatar
Car: 1991 Formula
hi guys
just wanting to get some opinions here on buying a complete ls1 with accessories and harness or building one
a friend of mine has one from his 98 trans am thats torn down he thought he had prblems with it and bought a 408, the stock one has been checked out and everything is ok
localy i can get one ready to drop in for around 3200 if i remember correctly if i build the my friend has i'll have to get the gasket kit accessories brackets and harness
my thinking is if i build it to bore it over and maybe stroke it, but unsure of stroking that engine as i'm not real famamliar with ls1 like on hawks webpage they have 408 and 416 short blocks how much bore and whatever is needed to acieve this
wouls i have problems running factory heads after doing this until i could get better heads
will a t5 tranny bolt up to an ls1? i know it's probably to much horsepower for it buthow long could i use it before it went out?
thanks in advance for any feedback
Old 11-30-2011, 04:29 PM
1quickirocz's Avatar
Car: 88 IROCZ
Engine: 5.3 Gen IV
Transmission: 4L65E
Axle/Gears: Moser 12 bolt 4.10
Re: buy complete ls1 or build it
Originally Posted by cphgncowboy
hi guys
From the way it sounds i think i would buy a complete engine with harness and all that. you will end up spending alot of money buying everything separate and reassembling the engine. Ask me how i know haha. As far as boring and stroking, you cant really bore an alluminum ls1 block. the most you can do is a little bit of a clean up hone job. The iron block LS series engines are the ones that can be bored. As far as stroking, there isnt really any clearancing that need to be done to the block. there is plenty of room for stoking. IM not 100% on the T5 trans but i dont think it will work. If it does it wont last lonng at all. Not trying to be a jerk but you may get alittle more response if you repost in the conversions LSX forum on this.
Old 11-30-2011, 09:28 PM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
The best way to do a swap is to have a complete donor car so you have the whole removal process in front of you and then know how to install it.
The further away from that and towards "I'll buy this, then that, and piece together this," the worse off you are.
Terrell351
06-13-2021 01:13 PM
1984HO
03-19-2021 11:59 AM
Casey Meyers
03-02-2016 10:46 AM
KO1
08-31-2015 06:31 PM
Quick Reply: buy complete ls1 or build it
