i hate my stock rear end gears !!!
Car: 1988 Pontiac trans am
i would like to get a slightly bigger gear , what are my options ? . BTW car is all stock .
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Re: i hate my stock rear end gears !!!
Senior Member My A$$.
https://www.thirdgen.org/gears
https://www.thirdgen.org/forums/faq-board/336194-thinking-4th-gen-
rear.html
https://www.thirdgen.org/4thgenrear
Go for Posi rear end, with 3:42 gears.
rear.html
my rear end is 9 bolt . i just hate how long it takes to get up to speed , probably help my MPG too since i would have to accelerate as much to reach the needed speed .
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Installing new gears requires some expertise (IMO) and tools that aren't normally found in a do-it-yourselfer's tool box. Best bet is another rear, a third- or fourthgen with the ratio and brake type you desire--along with limited slip perhaps. Considerations where a disc brake rear is concerned: the appropriate combination valve, the appropriate speedo drive and/or driven gears, and the appropriate parking brake cables.
The 10-Bolt FAQ may also provide some helpful information.
JamesC
JamesC
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Putting taller gears will make the car accelerate a bit faster, but it will be running at a higher rpm. Fuel mileage will suffer, not increase.
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
- never heard that before...
I have 2.77's and on the street seems to be fast enough - I am leaning toward 3:42's but with this 700R4 I'm worried that this first gear won't even be used for much. It does not stay in first long at all with 2.77's and 3.42's seem to be the popular route.
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Finding a 10 bolt from the junkyard and swapping it in is the easiest/cheapest route. That's my plan for this summer.
Car: 1992 Camaro RS
It depends on if you drive more on the highway, or more around the city. Changing to taller gears means you won't have to mash the gas peddle as much when you driving around the city to get up to speed, meaning less fuel consumption. However, if your driving on the highway and really only need to accelarate moderatly once, then you at a stable high speed for a long distance, your mpg will drop. So, taller gears equal better city mpg, but worse highway mpg. The 305 TBI gets about 18 mpg city and 28mpg highway. After a swap to taller gears, city mpg should inproove to about 21mpg, and highway should drop to about 23-24. I know I'll be doing mostly city driving, so I'll be swaping out to some 3:42 gears. Nuf said as far as fuel consumption goes.
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
i went from a 2.73 open to a 4th gen 3.42 posi disk rear and i get about 20mpg in the city not sure on highway yet mad a big difference
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
grab a rear from a v6 camaro car.most are 3.42.
I will look into a v6 rear end, any tips for what I should look for, avoid etc.
Engine: 305 tbi
Car: 85 IROCZ
Engine: 350 TPI with a fast EZ efi
Transmission: t-5 conversion
Axle/Gears: 3;42
I have a 85 IROC with 305 tpi, 700r and a posi 3:42. The only thing is the crummy gov lock diff. I changed it out for a auburn limited slip. What a difference
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
