t56 price at pick N pull?
Car: 1988 IROC-Z Camaro
Engine: 355 TPI
Axle/Gears: BW 9 Bolt 2.77 Posi
Re: t56 price at pick N pull?
The P-N-P site lists a transmission for $99.99 + a $29.99 core fee. Not bad!
http://www.picknpull.com/part_pricin...=&#partpricing
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Hah, good luck finding any T56 in a junkyard. Its possible I suppose, but very doubtful since they're an extremely desirable transmission for many, many hot rod applications.
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Best I found was when I asked the local Junk man. He said could get me one but even then he said would cost 1500 min just for the trans alone. Nothing else. Not sure the bellhousing was included. Best bet is craigslist or on boards like these. Usually you find everything you need for 1200-1500. Sometimes you get lucky and find one for under a grand.
Car: RS
Axle/Gears: 9" for the ladies
I can find lt1 t56's around here in the junkyard. Actually went to buy one before and they said $350 so I went to the ATM and came back with the cash but then they wanted more because I didn't have a core to give them
I showed them the wad of cash and told them they could go ____ themselves because they wouldn't be getting $350 when they crushed the car later.
For $1500 I'll go buy a complete hi mileage lt1
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
Honestly I think the best way to find a cheap T56 is at large salvage auctions. I've seen 93 to 97 6 speed camaros / firebirds that were trashed on the outside sale for 600 to 1000 dollars at a salvage auction. In most cases even if the body is trashed / been rolled, the transmission would be fine.
We have some local yards around here that have set prices for transmissions no matter what they are or what they came out of. I found a t56 in a z28 one time but didnt have the right tools to pull it so i went around the corner to the closest store and bought a little cheap set of tools but when i got back there was another guy pulling it out already.....that sucked!
Car: RS
While it's not called "gateway" yes that is the one I went to and it was in with the rest.
BlackphantomZ28
Apr 24, 2016 08:14 AM
