Do i have 4th gen rear end?
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Im thinking previous owner swaped the rear end to a 4th gen.one. What do u all think? Stock 91 wheels stick out to much and i dnt like it as much. Is there anything i can do to push those wheels in? I am guessing its a 4th gen rear cuz i really sticks out and i dnt think u can do that wth a 3rd gen rear unless u use spacers right? And last question, the 3rd gen axle shafts are enterchangable with 4th gen? Cuz wouldnt the 3rd gen wheels not fit if it was a 4th gen rear cuz of the bolt pattern?
Heres a pic of the rear
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG][IMG]
[/IMG] Joined: Aug 1999
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Do i have 4th gen rear end?
Third- and fourth gen axle shafts aren't interchangeable. The bolt pattern is identical.
EDIT: The thirdgen rear is approx. 57" from backing plate to backing plate and 62" from axle flange to axle flange.
JamesC
Engine: 350ci TPI
So their the same bolt pattern? If i put 4th gen wheels will sit more inside the fender? Cuz they stick out to much with my 91 wheels
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
To put 4th gen wheels on, the rear wheels will fit right on, but you'll need 2" bolt-on spacers for the 4th gen wheels to fit on the front.
Car: '83 z/28
Axle/Gears: Stock?
Just lower it and that would be some nice fitment! Or...Sell me the rims/tires and buy 4th gen rims/tires haha.
Engine: 350ci TPI
Haha im actually trying to look for one front wheel but yes dropping it on some sportlines is my next modd
Car: 92 Camaro RS, duh?
Engine: 305 V8... for now...
Transmission: MAN...ual
So... How does this effect driving? Does does fourth gen drive any different? Like, is there a noticeable difference?
No, the 4th gen wheels won't make any difference to how it drives at all, except for fixing that poseur stance that looks like cold leftover yesterday's a** with those pizza-cutter stock wheels on there.
But since the wheels stick out a bit more is there any issues with the tires hitting the fender anywhere?
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Are you sure you don't have the front wheels on the back?
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Front wheels on the back dont look anything like that. That is definitely fourth gen rear. This is my car with front wheels on the rear:
No one would know unless I told them.
Engine: 450HP 355
Transmission: TH350
Aah, ok. I remember doing that to my 91 RS but forgot how much the difference was.
So those of you with this swap, do you ever have issues with the back wheels hitting that lip on bumps?
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
go with some 88-96 corvette ZR1 replica rims in 17x11 and 17x9.5. I bought these from a 3rd gen guy who had them on his 90'ish metallic blue z-28. They looked awesome on his car but now my vette has them.
275/40/17 and 315/35/17
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
