700r4 wiring
Old Jan 4, 2012 | 01:57 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
700r4 wiring
Could bad wiring on the lock-up pin be causing my car to shutter/vibrate horribly bad? I unpluged it and the vibration stopped but I dont want to have to replace the converter if I dont have to...
Old Jan 4, 2012 | 02:35 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Re: 700r4 wiring
It could be the lockup solenoid on its way out. Its pretty easy to replace and costs about 20 bucks. I would give that a try first.
Below is what youl see when you drop the pan. The circled part is the solenoid. Remove those two 10mm bolts and pull it out. Cut the two wires going into it and hook up the new one. Depending on where you buy it, the new solenoid should come with connectors to splice it in.
Old Jan 4, 2012 | 02:38 PM
Car: 1988 Iroc-Z
Re: 700r4 wiring
Ok thanks man! Anything else I should look at?
Old Jan 4, 2012 | 02:41 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Re: 700r4 wiring
While you have the pan down replace the filter and check for any metal shavings on the magnet in the pan.
Old Jan 4, 2012 | 02:57 PM
Car: 1988 Iroc-Z
Re: 700r4 wiring
I've read that on 88 and older that the TCC is right by the TV cable... Correct or no?
Old Jan 4, 2012 | 03:07 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Re: 700r4 wiring
Im not sure, youll have to see when you open it up. I know 87 and up are a little different so it could be. It should look the same though.
Old Jan 4, 2012 | 03:14 PM
Car: 1988 Iroc-Z
Re: 700r4 wiring
Ok, thanks again bro!
Old Jan 5, 2012 | 01:28 PM
Car: 1988 Iroc-Z
Re: 700r4 wiring
I swapped the TCC solenoid and that was the problem! I had more metal than i'd like on the magnet but I'm going to replace the tranny in a few months anyway... I owe you a beer if your ever in Bama...
Car: 1988 Iroc-Z
Re: 700r4 wiring
P.S. it was in the spot you circled...
Old Jan 5, 2012 | 06:56 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Re: 700r4 wiring
No problem, glad i could help.
Old Jan 12, 2012 | 07:10 PM
Car: 1988 Iroc-Z
Re: 700r4 wiring
Well, it helped for a few days... its back to vibrating again but not as often or as intense. I'm just going to replace the tranny and put a stall in it that is non-lockup!
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
stalkier
Dec 6, 2015 11:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
g.l.mos
Aug 22, 2015 12:02 AM
